20 Most Recent
NorthPoint NP-9-HP Base CB Radio Questions & Answers
Radio hears well but has
look up the tune mods online for that model i couldnt find them myself but a power mic might be your solution.
White boy here, i'm installing a connex 4600tinto
you can use 8 gauge wire, this is only 190 watt radio, do put a fuse in line close to the battery. Wilson 5000.....wher are you going to mount this..I'm guessing that this is the trucker series antenna. You do know that the load has to be at the top of the roof? Again how and where are you mounting the antenna?
My cb radio is hooked up, has power, my driver amp
you might have a final issue and yes you should be able to talk and receive with the amp hooked up
and not under power.If you bought the radio used beware you don't know what the swr reading was on the last owners setup he could of burnd the final and it will affect your receive go get the radio tested cheap solution.
Icom IC706mk2g Transceiver does not transmit in SSB (Single Side Band) (USB & LSB)
First, make sure that the microphone is properly connected to the transceiver. Check all the connections and ensure that there are no loose cables.
Next, check the settings on the transceiver to make sure that it is set to SSB mode. Sometimes, the mode settings can get changed accidentally, so it's important to double-check.
If the issue still persists, try resetting the transceiver to its factory settings. This can sometimes resolve any software glitches that may be causing the problem.
If none of these steps work, it's possible that there may be a hardware issue with the transceiver. In that case, it's best to contact a professional technician for further assistance.
3/28/2024 10:24:30 AM •
Radio...
Answered
16 hours ago
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
