20 Most Recent Lasko 48" Xtra Air Tower Fan with Air Ionizer Questions & Answers
2answers
How to clean them
Clean your air tower fan by using small paint brush and wet rag(s). Turn off power and unplug, then open the fan by using screw driver either flat or crossed type. Eliminate dust and dirt using paint brush and rub it with wet rags. When disassembling put screws in box and be observant so that you'll able to assemble it later. Do not wipe motor with wet rags only the propeller, front back cover and so on.
Good luck.
11/12/2018 11:31:28 AM • Lasko 48" Xtra... • Answered on Nov 12, 2018
Lasko fan wont blow air
Sounds like the fan motor is the problem
8/31/2016 10:56:41 PM • Lasko 48" Xtra... • Answered on Aug 31, 2016
Osilating stopped on lasko 2554 fan
Lasko's are good for stripping the gear in the base that makes it oscillate. If it's still under warranty, they will send you a new fan.
7/29/2016 7:15:46 PM • Lasko 48" Xtra... • Answered on Jul 29, 2016
New Lasko Tower Fan smells when we have it on the ionizer option? Is this smell toxic?
Ionizers generate ozone, that is the same smell that you would have near an electric motor or a copy machine. The smell is caused by electric sparks that occur during the ionization process. Essentially high voltage is applied to a grid, air passes over this grid and electrons jump off of it and into the air. They then attach to any particles that are present in the air and make those particles attractive to anything less charged than they are. There is a limit to how much ozone an air ionizer is allowed to produce because ozone is a respiratory irritant and is not desirable to have in large amounts. Ozone also damages rubber. A commercial air purifier has to certify that it is in compliance with that law in order to be sold. The difference is that they can change characteristic based on how clean the grid is and how much humidity is present.
7/1/2016 6:27:06 PM • Lasko 48" Xtra... • Answered on Jul 01, 2016
How do I know which wires go where on a lasko tower fan, I'm trying to use the lasko motor on a blower
You have to cut the blue wire, WAIT NO, the red wire. No the blue wire, yes cut the blue wire. Phew that was close. (How the hell is anyone going to know the answer this question? you took the think apart so you can see what the wires are for)
12/3/2014 11:31:12 AM • Lasko 48" Xtra... • Answered on Dec 03, 2014
3answers
It turn on , revolve but no air comes out
I am having the same problem. Did you ever fix your fan?
6/14/2014 3:03:42 AM • Lasko 48" Xtra... • Answered on Jun 14, 2014
0answers
0answers
0answers
XA30I
Be the first to answer 12/12/2013 3:19:13 AM • Lasko 48" Xtra... • Posted on Dec 12, 2013Be the first to answer
0answers
0answers
Lasko E20739
Be the first to answer 9/21/2013 12:08:56 AM • Lasko 48" Xtra... • Posted on Sep 21, 2013Be the first to answer
0answers
Lasko 48" Xtra Air Tower Fan with Air Ionizer Logo
81 questions posted
Top Lasko Dryers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
View Most Popular
Lasko Dryers
  • Lasko Dryers
Most Popular Question
know wires go lasko tower fan
  • Dryers
