20 Most Recent
Shuttle XPC SD32G2 Barebone Questions & Answers
I got a used shuttle and i don't know the password
If there's no harddisk present, it means you need a password at hardware (BIOS) level, immediately at boot-up.The former owner should have provided this pwd to you. However, there's a work-around.1) Disconnect powercable2) Open casing3) Locate the CMOS-battery (it's a 3V CR2032 battery)4) Remove this battery from it's socket / holder5) Get a 100 Ohm resistor6) Connect both pins of resistor to the connectors of the batterysocket / holder. Hold this resistor for about 2 hours.7) Insert battery back again8) Close casing, connect powercable and turn on PC.
What is the command prompt
Command prompt is a non-graphical (DOS-like) screen and is mainly text-based.Think about the old computers.A command prompt can be opened in Windows, when touching the start-button(Left bottom corner), next selectng "Run" and type either "cmd" or "command" (without the quotation-marks) and push the ENTER-buton.When performed correctly, you should see a menu to pop-up with a black screen and white text.If you're not familiar with this command prompt, don't go for it. It's like the operating system of the old computers, or you can think of when there was no Windows (*). This is purely text-based.
Wont boot, wont display anything
remove memory boot should hear seris of beeps memory is clear,reinstall memory one at a time if it boots with one but not two have a bad memory stick
How to download files onto USB flash memory
Just plug the memory stick into your USB port on the computer. Windows has the drivers already installed. A taskbar icon will appeer us a connected USB device, exacly as a digital camera would. You will find the stick in My Computer as a removalble drive. Click on the right side mouse button over the flash drive icon and click properties to see the stick memory size, ect.... Use it as you would any other removable dirve, ie: 3.5" floppy disk, CD Read/Write. I would go to the TOOLS button for the drive and click FORMAT for you first use of the stick to test its memory. After that you can just copy, save, drag and drop files like always....
BIOS
hello their, I have fixes alot of computer happen like this. your computer has no operating system at that moment.. you need to install a fresh copy of window xp or vista OS. there is nothing wrong with your computer if this will work...........Just install ithope this helps..
Screen freezing up
Do your defrag from safe mode and see if that helps. There might be something running in the background that is messing it up.Another thing that could cause freezing is a bad hard drive. Have you run scandisk first before defragging? I'd strongly suggest it.
No video on boot!
This is not normally a bios problem. If you have a second video card in the computer, you might try to get video on that one. Otherwise, I would place the problem as one of two things: The video card or the power supply.I wouldn't try to flash the BIOS unless you have really good reason to suspect it.
How to download music onto
When downloading music, you normally save it to your hard drive. Then you can copy it from the hard drive to the USB drive. Just use copy and paste.
var fctb_tool=null;
function FCTB_Init_565da20502c2462dbcd9bb99859b321e(t)
fctb_tool=t;
start(fctb_tool);
var fctb_tool=null;
function FCTB_Init_be9da42caa7f42999179ad5cc596d2b6(t)
fctb_tool=t;
start(fctb_tool);
How can i reset my asus lop top
If you have a recovery partition on your hard drive then f12 or f8 on startup should do a factory reset on the machine else set your DVD drive as first boot device and put in your windows or Linux CD.
How to factory reset an asus eee pc 1000hd
What do yo mean by reset? Do you mean reload the operating system?
If your drive is ok, you should be able to boot to a recovery partition and reload.
If your disk is completely corrupt, you will need an external drive to load the operating system. Or you can do it with a flash drive that can boot.
I converted a Linux machine to Windows with a flash drive. You can Google it to find the method. It is fairly complicated.
It is not difficult to put Linux on it.
No video on boot!
How to Install Shuttle SD32G2 (FD32V1.x) 010a
This step-by-step guide describers how to obtain and install Shuttle SD32G2 (FD32V1.x) 010a drivers for Windows.
1. Define your Shuttle System device model.
2. Define your operating system to install your Shuttle System device. Note:
Update Drivers in Win Vista3. Browse System Drivers.
4. Find Shuttle System Drivers.
5. Select Shuttle SD32G2 (FD32V1.x) 010a.
6. Download Shuttle SD32G2 (FD32V1.x) 010a. Note: you can update all Drivers automatically with
RadarSync (Freeware) or
Driver Detective (Shareware).
7. Install Shuttle SD32G2 (FD32V1.x) 010a.
8. Restart or reboot your computer to finish your driver installation. Note: you can
backup your computer drivers before updating.
I have an asus g51vx that we have forgotten the
The best way to do this is using the Offline NT Password & Registry editor.
You can download it at the following link: http://home.eunet.no/pnordahl/ntpasswd/
Thisutility will enable you to reset the password of any user that has avalid (local) account on your Windows NT/2k/XP/Vista etc system.
The link above includes some directions on how to use this utility.
Hi i have an Asus lap top infected by a trogan
I hate to tell you this bud, but this will likely require a reload of your Laptop to fix the problem.
There are a bunch of programs out there that claim to be able to fix viruses, but few do the job well. And with Windows unusable, the job is even harder.
You may wish to buy a anti-virus program that allows you to create a bootdisk to clean the disk outside Windows, but there are no guarantees it will do the job.
If I were you, I'd reload it from scratch with a clean format of the harddrive. If you decide to go with the Anti-virus bootdisk route. I recommend McAfee Antivirus for the job. It appears to be the best at doing this.
Best of luck and let us know how it goes.
Factory restore
You can export address book:
click File -> Export -> Address Book -> Seleck "Text file(comma separeted values)" -> select folder on your usb drive you want to save address book, click next, select what info about your contacts you want to export.
