20 Most Recent
Philco PC-841.651 Turntable Questions & Answers
Turntable won't turn
In the middle of the TT youll Find a C-Clip It needs to be Removed before the Platter can be removed,You either have a Broken Belt,Or the Grease in the Guide is Old and must be Cleaned out and Relubed
9/14/2022 2:31:39 PM •
Philco...
Answered
on Sep 14, 2022
How can i make my girlfriend not crabby
Try listening to her needs more often. Surprise her with a home cooked meal that SHE would like. Spoil her a little. Best of all, let her vent her problems to you and don't offer advise unless she asks for it. Sometimes just being there to listen makes a world of difference.
7/24/2014 6:52:34 PM •
Philco...
Answered
on Jul 24, 2014
Turntable spins to fast.on 33
Possible that the motor is working with a different speed. It can be fault in the drive, fault in the mechanism.
What is required is the need to remove the TOP plate and look to see the drive of the motor. If there is slipping of the drive it can result in higher speed. If so it can be aligned and corrected.
7/12/2011 12:17:33 PM •
Philco...
Answered
on Jul 12, 2011
How to replace the electric cord
If it is the power cord, it should be of the universal kind. If it is the RCA cables, youu will have to strip back the wires and solder the ends together matching the wire colors. Tape up with insulation tape and "bob's your uncle"
7/12/2010 7:48:36 AM •
Philco...
Answered
on Jul 12, 2010
Turntable belt
The Belt goes arond the Inside rime Of the Table as you do this you will see a Motor thru the Opening there should be a Guide there that keep the Belt stright,(Unless the Belt is Rubbery,And at which Point Go to PRB Belts and Order one
12/15/2008 3:48:38 AM •
Philco...
Answered
on Dec 15, 2008
Power supply
This unit takes a 12V 0.5A DC power supply. Your local Radio Shack sells this type of supply that will plug into the wall. You'll need to make sure that the other end will plug into the turntable, but for the supply, Radio Shack is probably the quickest way.
8/4/2008 6:02:50 PM •
Philco...
Answered
on Aug 04, 2008
