20 Most Recent Numark TT1650 Turntable Questions & Answers
5answers
0answers
0answers
Slow
Be the first to answer 7/23/2013 3:41:06 AM • Numark TT1650... • Posted on Jul 23, 2013Be the first to answer
Numark TT1650 When I hit switch
witch one IC needs to be replaced ? i have same problem in my 2xtt1650
11/5/2012 9:22:05 PM • Numark TT1650... • Answered on Nov 05, 2012
0answers
How do i hook a numark tt 1625 turntable to a
Turntables require a special input in the amp (usually marked PHONO) because they require high gain and different equalization - and yes, that ground wire has to go to ground unless you want to get a super annoying 60Hz hum from it!
If your amp doesn't have a phono input, you're going to have to go out and get a phono pre-amp and connect it between the turntable and the amp.
Best of luck!
2/26/2011 4:26:11 AM • Numark TT1650... • Answered on Feb 26, 2011
Hi there! i just bought a numark tt1650 and an
Try connecting the turntable to one of the other inputs like CD / tuner etc and see if the buzzing disappears. if so then your turntable has a built-in pre-amp so it can be connected to any input except 'phono' as this would obviously be used for turntables without a pre-amp.
a lot of modern turntables now have built-in pre-amps to compensate for certain amps and receivers made without a phono input and can now be connected just like a CD player, tuner etc.
hope this helps.
9/11/2010 11:47:17 PM • Numark TT1650... • Answered on Sep 11, 2010
How do I get my sound from my Numark TT1625 to
You need a magnetic cartridge preamp. You then plug your turntable into it and the box into the CD/aux imput of your amp.
5/21/2010 11:16:47 PM • Numark TT1650... • Answered on May 21, 2010
Brand new numark tt1650 makes a buzzing sound when
Maybe too close to the speakers causing "feedback". Otherwise
need more info on the noise!
5/4/2010 4:03:57 AM • Numark TT1650... • Answered on May 04, 2010
No signal going into mixer.
Turn Up The Master Level
4/11/2010 3:41:40 AM • Numark TT1650... • Answered on Apr 11, 2010
Tone Arm acting as arial
A metal tone arm has a ground wire that connects it to the back of the stereo via the Turntable chassis. If this wire is broken (inside the deck of the turntable) or the ground to the stereo is not done, you can have this issue. No, the ground through the audio connectors is not sufficient.
3/20/2010 6:02:27 AM • Numark TT1650... • Answered on Mar 20, 2010
Hi,i need a mains transformer
that turntable wasnt made in the usa . your best bet is to google the same info.
ask where to buy that transformer etc. good luck
8/15/2009 12:26:12 PM • Numark TT1650... • Answered on Aug 15, 2009
Second hand decks
The unit should not be making any sounds like that. It sounds like the timing is off for the gearing underneath the platter. It may be as simple as cleaning the existing grease on the mechanism and re-lubing. The existing grease may have gummed up a bit not allowing the parts to move freely. Take of the bottom and look at the condition of the grease.
Dan
1/27/2009 1:15:42 PM • Numark TT1650... • Answered on Jan 27, 2009
I brought a set of
Dan
1/27/2009 1:08:47 PM • Numark TT1650... • Answered on Jan 27, 2009
Numark TT1650 Turntable Logo
25 questions posted
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Numark Audio Players & Recorders
Most Popular Question
just bought numark tt1650
  • Audio Players & Recorders
