20 Most Recent
Kenwood KDC-X591 CD Player Questions & Answers
KDC-X591
Kenwoods are awesome. Read the manual, sometimes it gets confused with the Folder trees, if you have to many it goes crazy. It could also be the way the disk is burned, and how the songs are named. I beleive in display options too you can click how things are displayed i.e. folder, artist, song name, title, time. Read your manual.
USB folder names-Kenwood KDC-X591
Push the AME button in the upper right hand corner of the unit and at the same time hold the fast forward button on the face of the unit - do this for 5 secs. The word "Code" should pop up (not blinking).
Using your remote control press the following numbers:
5 (two times for letter "K")
2 (three times for letter "C")
2 (one time for letter "A")
7 ((two times for letter "R")
Then using your remote control, press the fast forward button and you are done. "Approved" should pop up on the unit.
Hope this helps!
Where is the mp3 plug
The USB and Aux. connections are on the back of the unit. Here is a website with the specs for it.
http://www.crutchfield.com/p_113KDCX591/Kenwood-Excelon-KDC-X591.html?tp=5684&tab=features_and_specs
I need the code for
You can enter a 4-digit security code which must be used when the unit is removed from the vehicle, or the constant power source is disconnected from the unit. When constant power is restored to the unit, the security code must be entered before the unit becomes operational.
If the code is lost or forgotten I am afraid the unit has to be re-coded by a Kenwood dealer.
Good luck with it.
I need to find out
your ipod aux goes to the back of the radio but you need to buy adater KCA-iP200 (Sold Separately.
How remove code
Can you explain in detail what problem you are facing so that we can direct you in right direction . What is code you are getting ?
Waiting for your reply .
Where do i plug my ipod?
there should be a long ipod cable on the back of the radio. most people route it through the glove box.
