20 Most Recent
Acoustic Research AW-721 Consumer Headphones Questions & Answers
Acoustic research aw722
No need to plug into the back jacks on the TV or change the out put of the tv audio source to the Front jacks
8/26/2014 12:50:49 AM •
Acoustic...
Answered
on Aug 26, 2014
I need ni-cad battery specifications for Acoustic
The AR AW721 headphones require 3 AAA NiMH batteries, not Ni-Cad. The original batteries are 1.2 volt, 550 mAh. I replaced mine with Energizer 850 mAh AAA batteries, which work well and actually last longer per charge than the originals.
8/14/2011 6:34:18 PM •
Acoustic...
Answered
on Aug 14, 2011
Where can I get replacement earpads for the
http://www.gifts.com/ssp?slkw=replacement%20earpads&testcell=B&adid=1288827692-1992034d-0-p-gf_mps&ref=replacement%20earpads%20for%20aw721&creativeid={creative}&site={placement}
1/13/2011 2:41:55 AM •
Acoustic...
Answered
on Jan 13, 2011
I got a pair of this acoustic research head
I hope this one is not kept too long idle and without charge. Check on the points and the connections and try again maybe put it on for sometime to enable time for triggering any low voltage stage from where it has to recoup. Hope this will help
7/1/2010 7:20:46 AM •
Acoustic...
Answered
on Jul 01, 2010
12/22/2008 5:55:34 PM •
Acoustic...
Answered
on Dec 22, 2008
Sound from only one headphone
I purchased an AW 771 set in "as is" condition which on arrival produced output only from one side. Repair was effected by removing 8 phillips screws, 4 from each side, concealed under the ear-surrounding doughtnut-shaped cushions. To expose those screws, the ear cushions must be pushed from their center toward the outside. Black screws in back holes surrounded by black acoustically-transparent cloth does not make them obvious.
I used a volt-ohm meter to find a discontinuity at a failed solder connection. Resoldered that connection, rechecked electrical continuity to be certain all connections were good. Tested with batteries installed using an audio input. Both sides produced sound. Replaced screws and they have performed very well since then.
I hope this Model AW771 experience is helpful in restoring your AW-721 to working order.
John
2/13/2008 3:05:14 AM •
Acoustic...
Answered
on Feb 13, 2008
Operating manual
After connecting all cables.... try channel 1 at the receiver... then move tuner up and down until the green light on the left headphone lights up and you can hear whatever you are listening to. If channel 1 doesnt work, try 2 and 3...... mine is set on CH3.
Good luck
11/23/2007 8:10:40 PM •
Acoustic...
Answered
on Nov 23, 2007
I have a pair of acoustic research "active
DC 12v adapters are common and I think that would work. The similar "Powered Partner" speakers used a 14v DC adapter. Just check the size of the plug and the configuration (center pin is +). Radio Shack and other sellers have universal adapters.
12/2/2015 9:14:45 PM •
Acoustic...
Answered
on Dec 02, 2015
Subwoofer wont power auto on
your question too brief, no one can help. be more details so that can understand on your problem. or else there may have too many possibility to cause the problem happen.
2/4/2014 12:03:01 AM •
Acoustic...
Answered
on Feb 04, 2014
