20 Most Recent Mitsubishi WD-57732 Projection Television Questions & Answers
While watching TV red light come on and screen
unplug the tv, wait 5 mins plug it back in, and without using the remote, press the tv on button. see if its ok.
1/18/2018 11:14:01 AM • Mitsubishi... • Answered on Jan 18, 2018
My tv keeps shutting down when I turn on. The
The first would be excessive dust causing inadequate airflow through the lamp cage. Cleaning the filter may resolve the problem. It could also be that one, or both, of the temperature sensors could be defective. This is a known problem to the extent that Mitsubishi extended the warranty an extra two years on your model and similar models with the same design. Mitsubishi Digital Electronics America, Inc (MDEA) 2006 DLP® Projection Televisions Models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD- 65732, WD-57831, WD-65831. As part of our commitment to quality and customer satisfaction, MDEA is announcing an extension of the warranty coverage to replace the thermal sensor for the above referenced models. For a period of two additional years beyond the one year limited warranty, MDEA will cover the cost of the thermal sensor (parts and labor) at no charge. All other terms of the MDEA limited warranty will continue to apply.
12/3/2017 3:18:29 PM • Mitsubishi... • Answered on Dec 03, 2017
0answers
TV flickers
Be the first to answer 4/15/2017 12:12:03 AM • Mitsubishi... • Posted on Apr 15, 2017Be the first to answer
Error code 21
Try a hard reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
3/11/2017 1:41:44 PM • Mitsubishi... • Answered on Mar 11, 2017
Bulb is out. Are there adjustments to mirrors or anything when just replacing the bulb? Would buying the full housing assembly be better?
just replace the lamp, no adjusts needed. I recommend a Phillips, OSRAM, or the original Mitsubishi lamp, as others will either not work or have a very short life. http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-57732
4/29/2015 6:50:32 AM • Mitsubishi... • Answered on Apr 29, 2015
My replacement bulbs keep burning out within 30 days. I took a closer look and there is a small square piece of glass that sits next to the lamp housing. It looks as if the light from the lamp goes th
Something is definitely wrong if you are consistently only getting a month out of a bulb. Either something is overdriveing the power to the bulb (unlikely) or there is a vibration or something is intruding on the bulb itself. Good luck and let us know what you find on this.
1/8/2015 8:58:43 PM • Mitsubishi... • Answered on Jan 08, 2015
Dead lamp!!!
is it tha lamp cracked? are you using original lamp from mits? i founded people using aftermarket lamps with other specks this lamp is 150 watts ,this info its going to help.
if components on the Power board K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects are a deformed lamp exhaust duct and damaged lamp. Replace PWB-POWER part # 934C228003 and if necessary, Lamp part # 915P049010, Lamp Exhaust Duct part # 642B155010, and/or Lamp Exhaust Duct Cover part # 642B156010 let me know if you need anything else
8/20/2014 11:04:54 AM • Mitsubishi... • Answered on Aug 20, 2014
0answers
Wont stay on
Be the first to answer 3/23/2014 4:34:27 AM • Mitsubishi... • Posted on Mar 23, 2014Be the first to answer
0answers
Timer
Be the first to answer 3/19/2014 3:26:04 AM • Mitsubishi... • Posted on Mar 19, 2014Be the first to answer
Dlp bulbs last less than 2 months
Buy nicer bulbs.
1/5/2014 3:27:22 PM • Mitsubishi... • Answered on Jan 05, 2014
Mitsubishi WD-57732 LAMP continuously burns out.
There are a few issues here:
The lamp you are purchasing could not be OEM, or a compatible lamp--OR you have a ballast/power supply issue blowing the lamp out.
The original lamp is manufactured by Osram, but a better and compatible lamp would be Philips, who pioneered the lighting for DLPs. The ballast needs to be compatible with the lamp and Mitsubishi ballasts are compatible with most lamps, but work best with Philips and Osram. Only buy from an authorized dealer!
5/30/2013 2:00:11 AM • Mitsubishi... • Answered on May 30, 2013
I have a Mitsubishi WD-57732. The problem started
Lamp did not turn on at P-ON sequence
(No Lamp inserted)
(Disconnected cable between ballast and lamp)
(Lamp-Enable goes to DM but not to Ballast) It's related to the lamp.
5/30/2013 1:04:32 AM • Mitsubishi... • Answered on May 30, 2013
Picture perfect for about 15 minutes after bulb replacement...
Is the screen kinda pink and blurry with white bars?
2/25/2013 7:00:02 PM • Mitsubishi... • Answered on Feb 25, 2013
Format not working
If the model here is correct clarify what set is doing or not doing?
12/22/2012 2:49:18 PM • Mitsubishi... • Answered on Dec 22, 2012
WD57732 Will not trun on. Red light on, No noise from Engine, Sound works
Which light is red?
12/10/2012 11:48:13 PM • Mitsubishi... • Answered on Dec 10, 2012
Power supply was cut
you can buy a new power cord or you can use another wire to replace the cord. just buy the same size then you will need to remove the rear cover to access the internal. and then the old cord must be removed from the ac terminal pin and the assembled wire with plug that you buy can be replaced. you can directly re soldered the end of the ac wire at the pcb for ac supply.
8/16/2012 4:24:17 AM • Mitsubishi... • Answered on Aug 16, 2012
Mitsubishi WD-57732 Projection Television Logo
81 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
t v making
  • Televison & Video
