20 Most Recent LCDDigital LCD7 Television Questions & Answers
Just purchased the 7 in portable TV/DVD player. I
Are you close enough to local broadcast stations to pick them up, can you hook up cable to it?
11/23/2017 7:14:52 PM • LCDDigital LCD7... • Answered on Nov 23, 2017
DSE LCD TV GE6400 keeps asking for a pin code that
Hi this code is the parental code or child lock, I believe, now, the reset code is in the user manual, I have searched online for the manual, however I have been unable to find one? All I can suggest, and as it is a **** Smith product, that you contact a DS shop, and ask them how to reset their product, or ask them where to obtain a user manual?
7/5/2011 10:55:27 AM • LCDDigital LCD7... • Answered on Jul 05, 2011
0answers
No sound on tv
Might have to check from the speakers , the audio output IC's and the preamp circuit.
it will be easy to find out with a audio signal test applied from the output and moving backwards.
If the test proves good till the preamp it can be the fault in the audio processing , the SIF.
9/29/2010 4:50:02 AM • LCDDigital LCD7... • Answered on Sep 29, 2010
No Picture, The power and the OPC Led's are blinking
Your TV is in fault protection. Due to blows caps on the PSB-power supply board.
Best Regards and Semper Fi
8/3/2010 6:42:34 AM • LCDDigital LCD7... • Answered on Aug 03, 2010
I returned an LCDDigital 7
did you send it certified or something saying delivery confirmation? address of where it was sent. Was there an RMA number on the box? Check with the post office and ask for supervisor next time you call.
3/14/2010 3:58:41 AM • LCDDigital LCD7... • Answered on Mar 14, 2010
Display problem
if this is a portable tv or an older one your state might have gone to digital programming therefore you can only get canada stations only. but try your brightness/contrast controls and make sure they are not low.
3/14/2010 3:34:39 AM • LCDDigital LCD7... • Answered on Mar 14, 2010
Magnavox 42mf438b/27 color distortion.
do to menu; then change the brightness/contrast/sharpness/color controls down also make sure the tint is in the middle.
3/14/2010 3:31:02 AM • LCDDigital LCD7... • Answered on Mar 14, 2010
There is a black mark on my 42 inch lcd tv it is
if you just got it take it back to the place where you have bought it. contact emerson and tell them about it. also, make sure you purchase an extended warranty next time if you have not done so. also, check and see if it has been recalled. if it is on your screen then i would use a eyeglass clearner to clean the spot.
3/14/2010 2:57:55 AM • LCDDigital LCD7... • Answered on Mar 14, 2010
Olevia 427-S12 no volume how do I get the volume
says no signal
3/6/2010 4:14:55 PM • LCDDigital LCD7... • Answered on Mar 06, 2010
Finding the pin number
I saw a piece in the local evening paper, which said "if a code number is required, use '1234' or '0000'" The '0000' worked.
Thank you
10/1/2009 10:04:09 AM • LCDDigital LCD7... • Answered on Oct 01, 2009
Remote needs to be too close to TV
try getting a universal remote
6/6/2009 1:18:16 PM • LCDDigital LCD7... • Answered on Jun 06, 2009
Stressing out!!
Alba TVs are manufactured in Albainia and the service info is next to impssible to obtain. I would try to troublehoot the deflection circuits. Possibly horizontal output or one of the regulators.
5/16/2009 6:43:38 PM • LCDDigital LCD7... • Answered on May 16, 2009
LCD Monitor
It's much cheaper to go ahead and replace the whole set because the T.V.s are so cheap that they cost less than the repairs.
8/23/2007 9:56:31 AM • LCDDigital LCD7... • Answered on Aug 23, 2007
Where is the Google on the Matertech?
It appears that there could be miscommunication. As of my previous update in January 2022, Matertech doesn't seem to be a commonly known term or corporation. On the other hand, if you're talking about "Google," it's a well-known worldwide technological corporation that specializes in internet-related services and goods, such as search engines, cloud computing, online advertising technologies, software, and hardware. Google's official website or an internet search utilizing one of the search engines like Google itself are usually the easiest ways to get information about Google. If "Matertech" relates to a particular thing or idea, further information could be helpful in order to provide a more precise answer.
4/16/2024 4:37:21 PM • Televison &... • Answered 5 hours ago
2answers
Changhong tv
Refer its user manual for details.
4/16/2024 3:46:48 PM • Televison &... • Answered 6 hours ago
2answers
My Telefunken television model TLEDD-42FHDB remote made tv on/off switch flick and remote has stopped working now. Still doesn't work after replacing batteries.
Put the batteries back in and aim the front ot the remote at the front facing selfie camera on a smartphone. Press a button and you should see a flash. If no flash, the remote has failed. If there is a flash, the television IR module or main board has failed.
Telefunken Replacement TV Remote TLED-26FHDPA
Soundtech https://soundtech.co.za > telefunken-replacement-tv-rem... Telefunken replacement remote compatible with TV models: TLCD-29FHDP TLCD-32FHDA TLCD-32HDA TLCD-37FDHA TLCD-37FHDA TLCD-39FHDP TLCD-40FHDC TLED-26FHDPA ZAR 199.00 ..
4/15/2024 10:04:39 PM • Televison &... • Answered 24 hours ago
2answers
Venturer KLV39103 10" Kitchen LCD TV/DVD Combo. I need an adapter to change to HDMI for an EVOForce cable box. Where can I buy one.
Question edited for a lot more clarity, full 'make model (what it is)'. There is more to this that meets the eye because your set is analogue and the new cable box is digital. Have a read
Is it possible to modify my kitchen Venturer KLV39103C tv in
JustAnswer https://www.justanswer.com > TV Problems Jun 9, 2021 - Your TV has only one external input and it's an analog coaxial input, hence why the converter and modulator will be needed. 1 answer ยท Top answer: You are very welcome. In my opinion, it would be much simpler to simply j More here https://www.google.com/search?q=venturer+klv39103+convert+to+digital ..
4/14/2024 8:05:32 PM • Televison &... • Answered 2 days ago
2answers
LCDDigital LCD7 Television Logo
19 questions posted
Top LCDDigital Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a LCDDigital Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • LCDDigital Televison & Video
Most Popular Question
dse lcd tv ge6400 keeps asking pin code
  • Televison & Video
