20 Most Recent JVC DR-MV7 DVD Recorder/VCR Questions & Answers
Not able to record movies/shows from cable box onto dvd recorder
Sorry I can't answer directly but just wanted to suggest you bought a PVR or personal video recorder that uses a computer-type hard drive. These devices are a lot less hassle when only short-term storage is needed and any content you want to keep can be recorded later onto hard copy. I still prefer vhs for that as it is possible to edit tapes or cut out bad portions if something goes wrong - not something easy to do if a cd or dvd gets damaged.
3/24/2017 9:54:32 PM • JVC DR-MV7 DVD... • Answered on Mar 24, 2017
0answers
Remote code
Be the first to answer 10/4/2013 5:00:01 AM • JVC DR-MV7 DVD... • Posted on Oct 04, 2013Be the first to answer
Clean ? Repareable ? Trash ? Sell as is?
The laser pickup assembly is shot, over time the laser becomes weaker until it can no longer read the disc,it is time to retire the item, far cheaper to replace the entire unit.
3/13/2012 12:33:25 AM • JVC DR-MV7 DVD... • Answered on Mar 13, 2012
Need owners manual for JVC
http://books.jvc.com/booklist.asp?Model=DR-MV77SUS
5/31/2011 6:29:11 PM • JVC DR-MV7 DVD... • Answered on May 31, 2011
I have borrowed a JVC
First of all, here is the main ONLINE SUPPORT page for your model:
http://support.jvc.com/consumer/product.jsp?archive=true&pathId=115&modelId=MODL027682
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://resources.jvc.com/Resources/00/00/93/LPT1133-001A.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, and then just follow the onscreen instructions to install it.
See page 39 of the ONLINE USER'S MANUAL for detailed instructions on how to DUB FROM VCR TO DVD.
Thank you very much and good luck.
4/22/2011 11:24:19 PM • JVC DR-MV7 DVD... • Answered on Apr 22, 2011
I lost the remote control,
There should be a rewind button on the front of the main unit (usually indicated by either REW or 2 arrows pointing to the left), this should be next to the fast forward (again indicated by either F-FWD or 2 arrows pointing to the right) as well as PLAY and STOP - for the VCR. The only thing you would need the remote for is to set the clock and/or perform setup for the DVD player as well as timer recording. Try a universal remote which will make fast forward, play, stop, record (to VHS) and rewind easier.
4/11/2011 11:19:40 AM • JVC DR-MV7 DVD... • Answered on Apr 11, 2011
I NEED A MANUAL FOR
here is the link you need to download the user Manual also you are going to need the full model number.
please don't forget to rate
1/23/2011 8:03:43 PM • JVC DR-MV7 DVD... • Answered on Jan 23, 2011
I HAVE A JVC DR-MV7
Actually your DR-MV7 has set on Progressive Scan mode, turn it off to get its normal picture or hook it in Component Video input of tv to get its progressive scan mode picture.
And if it is already hooked in component video input of tv then check picture resolution of your tv that seems set on 480, please change it to 720p to watch dvd player correct picture.
Hope this info will help you.
Thanks.
5/10/2010 12:26:50 AM • JVC DR-MV7 DVD... • Answered on May 10, 2010
Our DVD will not read discs. Some that we bought
I'm assuming you bought the DVD recorder in Asia as well. US DVDs are region 1 and won't play on a player/recorder from another region without alteration. (See http://en.wikipedia.org/wiki/Dvd_regions for a description of DVD regions). There's nothing as simple as a switch unfortunately.
You may be able to find a way of altering your recorder to play all regions (region-free) but you need to be careful when doing this. Here is one person's story of this going wrong with the same model JVC.
A safer alternative may be to buy another recorder in the USA.
4/11/2010 1:17:12 AM • JVC DR-MV7 DVD... • Answered on Apr 11, 2010
I have a DR-M10S which
New ones are designed to do that in order to keep people from boot legging disc/
1/9/2010 11:00:49 PM • JVC DR-MV7 DVD... • Answered on Jan 09, 2010
My jvc dvd /vcr combo will not record
From the explanation, it looks like you are trying to record TV channel, correct? Some of these DVD VCR combos may not have built-in tuner. Do you have the instruction book? If not, you can download from jvc.com website. If you find it difficult, tell me the model number.
11/15/2009 6:11:08 AM • JVC DR-MV7 DVD... • Answered on Nov 15, 2009
My unit will not read dvds but plays music cds
dvd player is **** on rEAD. will not eject dvd.
10/26/2009 10:04:04 PM • JVC DR-MV7 DVD... • Answered on Oct 26, 2009
The vcr part will play but the dvd won't. It show
Sometimes DVD have PAL versions sold here in US. Check the manual to see if it is PAL not NTSC
10/1/2009 6:12:28 PM • JVC DR-MV7 DVD... • Answered on Oct 01, 2009
2answers
Door opens and closes 3 times
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} t needs to be realigned
unplug power
open unit
clip_image001.jpgremove dvd drive (4 screws)
remove power cable to dvd right rear of unit on circuit board
(squeeze plastic connector and pull up)
remove ribbon cable CAREFULLY wiggle it from side to side and it will come up clip_image002.jpg
Then with drive removed, open up drive to access the bottom near front door
Once open you will see a smalll motor and a white pice of plastic that slides. with tray closed slide that piece of plastic as far towards the middle as it will go clip_image003.jpg
with that slid all the way over you should be done.
close it up and be carefull sliding the ribbon cable back into place
Worked for me!
Good luck
10/1/2009 5:40:50 PM • JVC DR-MV7 DVD... • Answered on Oct 01, 2009
JVC DR-MV7 DVD Recorder/VCR Logo
Popular Tags
42 questions posted
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
not able record movies shows from cable
  • Televison & Video
