20 Most Recent
Toshiba SD-K860 DVD Player Questions & Answers
DVD player will not open
try unplugging it for about 2 minutes to clear some memory and try it again. the tray motor may be shot or skipped a tooth on the gear and not hitting the switch. you may need to take the cover off and physically do it.
Stops playing in the middle of the movie.
Sound like the disc is stopping inside the player this can happen when you push the tray into the player instead of using the eject/insert button. This can cause the tray to slip its guide plug on the rack and pinion tray release this will also cause tray blocked unknown disc errors, this will need to re-seated.
It is also caused by excess dust and finger grease inside of the player that can build up over a number of years I suggest that you first unplug and then remove the lid from the device give the plastic internals a clean with rubbing alcohol.
DONT TOUCH the record/play head or power up with the lid off.
Will not power up. fuse is good.
Usually you cannot buy replacement powersupply boards for dvd players unless you buy a scrapper one off an auction site and use that , but before you go out spending any money, check the capacitors on the board which look like little blue cans, see if they have a buldge in the top and if they have then they will need changing. Check for any burnt components too.
jon
Every DVD gets stuck with "Loading"
could be just the mechanism that detects whether theres a disc in.
Have to open it up to find out tho, not a good idea unless you know what youre doing.
Change batteries on my toshiba se-r0001 remote
- Locate the Battery Cover: Look for the battery cover on the back of the remote control. It is usually a small compartment that can be easily opened.
- Remove the Battery Cover: Depending on the design, there may be a latch, screw, or sliding mechanism to secure the battery cover. Use your fingers or a small screwdriver to open the compartment.
- Remove Old Batteries: Take out the old batteries from the battery compartment. Pay attention to the orientation of the batteries, so you know how to insert the new ones correctly.
- Check Battery Polarity: Take note of the positive (+) and negative (-) signs inside the battery compartment. Make sure to insert the new batteries with the correct polarity to match these markings.
- Insert New Batteries: Place the new batteries into the battery compartment, ensuring they are properly aligned with the correct polarity. Press them down gently to make sure they are secure.
- Replace Battery Cover: After inserting the new batteries, close the battery compartment cover securely. If it has a latch or screw, make sure it is fastened properly.
- Test the Remote: Point the remote at the device it controls (such as a Toshiba TV) and test whether it responds to your commands. If the remote is working correctly, you have successfully replaced the batteries.
- Dispose of Old Batteries: If the old batteries are no longer usable, make sure to dispose of them properly. Many communities have designated recycling locations for batteries.
3/9/2024 3:29:56 AM •
Toshiba...
Answered
on Mar 09, 2024
