20 Most Recent
Canon imageRUNNER C3220 Color Copier Questions & Answers
The rip on the copier is flashing FF and I am not able to print
Hello. The FF is a hexadecimal number that means the rip did not boot properly.There are buttload of reasons why this my be but lets try this. Power off the copier and the Fiery emulator (rip).Power on the copier only and let it reach aready condition.Then energize the rip and watch the same display that showed the FF.It may take a minute or two as it goes thru its boot/diagnostics,but we hope you dont get the FF again.Now I am assuming that what we are talking about is a previously configured system that had been working fine until recently.If this is so,and the rip does not operate correctly after the directions I just gave then you probably need to re-load the rip's system software.
5/29/2020 1:25:48 PM •
Canon...
Answered
on May 29, 2020
Error code E000003-0001
Unfortunately you need a tech, unless you are a handyman.
there is a problem with the fuser,
either the thermistor ( heat regulator)
the thermofuse ( fuse)
or the heat lamp has gone bad
10/23/2019 1:47:13 PM •
Canon...
Answered
on Oct 23, 2019
ERROR CODE E000020-01b0
your yellow drum unit is bad replace it if the error ship to 000020-02b0 replace all your drum unit because all the units could be bad but the machine will show one at a time as you replace the drum units
5/2/2017 2:55:27 PM •
Canon...
Answered
on May 02, 2017
Colors are off registration
this problem can sometimes cause by uncalibrated machine upon replacement of major parts such as assemblies. or parts related to fusing, developing of drum related parts
mis registration of colors can appears if you machine isnt calibrated nor cleaned correctly, try going throug a resetting or set up procedure from your maufacturers manual
this would surely resolve your problems
1/29/2016 1:49:51 PM •
Canon...
Answered
on Jan 29, 2016
Error code E000732-0001
This error indicates that it cant detect the scanner unit of IRC3220
Check the cable that connect the machine and scanner unit .switch off the machine disconnect the cable and reconnect it and switch on the machine again hope this will help
1/8/2016 7:56:18 PM •
Canon...
Answered
on Jan 08, 2016
Canon IR 8500 Error code E000069-0000
You have a high-voltage leak to the transfer corona. This could be due to several different things, usually it's a dirty corona, maybe excessive dust or toner in the corona assembly. Toner conducts electricity and can leak voltage from the transfer corona to the frame. It may also be the "end-blocks," the thing in the back of the machine into which the transfer corona plugs when you close the drawer and lift up on the green handle. These crack and can cause intermittant failure.
I would start by taking a can of air and thoroughly blowing out the corona assembly and see what that does for you...
10/26/2015 6:49:19 AM •
Canon...
Answered
on Oct 26, 2015
