20 Most Recent
Gold Medal 2408 Popcorn Maker Questions & Answers
Do you do popcorn machine 8oz stirring rod please?
Your question has more questions than answers. You choose a Gold Medal 2408 Popcorn popper as your model, but it does not have a 60ktyz motor, the stir rod and shaft are separate from the motor, and you can't get parts for it on ebay.What model machine do you have?
What was the use date on the Gold Medal flour?
You are probably concerned about the recent Salmonella issue?
The product is the UNBLEACHED all purpose flour:
Gold Medal Unbleached All Purpose 5LB Flour Package UPC: 000-16000-19610-0 Recalled Better if Used by Date: 20APR2020KC
The "use by date" is ink dot printed on each package, usually toward the bottom of the package somewhere.
Trying to find kettle wiring drawing 3255
To order a manual from the factory the part# is 67834. Depending on how old this is , those kettles and or similar design had a issue with the nut comming loose that holds down the thermostat thight to the bottom of the pan. The loose nut would then bounce around in there until it touches a elect.connection and ground at the same time. It will short circuit the kettle and end up welding itself in place . so when you turn the kettle on it trips the circuit rite away. you have to dissasemble it and remove it . there is a new locking type nut avalible to replace it.
Popcorn burns
If the corn/ oil ratio is correct , check the thermostat operation . It is burning because it's in there too long from lack of heat to make it pop.
Gold Metal Popcorn Machine 1618 ETS
That is a 16 oz popper with big eye electonics, With a Target Store Neon sign. This model was only sold to Target Corp.
There is no question here.
