20 Most Recent
Panasonic DP-C213 Color Copier Questions & Answers
DP-C213 Panasonic Copier
The DP-C213 is still a current model for Panasonic. Go to Panasonic's website and find a local dealer to help you. --
To clarify, what company did you purchase or lease the mfp from?
6/30/2012 8:29:25 PM •
Panasonic...
Answered
on Jun 30, 2012
I've got the above mentioned copier. It was
Hi Michael, we will just need to turn off that function in service mode, when i get some time in the office today I'll get the manual out and let you know how we can disable it, its 6am here in oZ and I'll hit the office around lunchtime, and I need to look this one up, so I'll email you the answer around then.Talk soonCheersSteve
10/10/2011 7:14:39 PM •
Panasonic...
Answered
on Oct 10, 2011
I need to istall my
You can get the postscript printer driver here, assuming your printer has the postscript option installed. Also other note is that this driver only supports up to the Leopard operating system (10.5). No drivers yet for Snow Leopard (10.6). The installer crashes when trying to install on 10.6
http://panasonic.net/pcc/support/mfp/dp-c354/ps/download.html#02-3
3/8/2011 1:12:57 PM •
Panasonic...
Answered
on Mar 08, 2011
My Panasonic dp c213 says
There are two Drums for this unit, one for black color ( DQ-UHN36K) and one for color (DQ-UHS30).
For step to step instruction to change the drum see this link...
ftp://ftp.panasonic.com/pub/Panasonic/business/office/op_manuals/op_man_printer_multi/OM_DP-C354Series_BasicOps.pdf
You will find instruction on page 80 and 81.
2/28/2011 3:39:16 PM •
Panasonic...
Answered
on Feb 28, 2011
Driver Window 7
you may want to take a look at this page
it maybe worth your while taking a look at the support documentation for Windows 7 drivers
9/20/2010 8:58:28 AM •
Panasonic...
Answered
on Sep 20, 2010
Panasonic DP-C213 is not printing. I have a
hello,
if it is failing at the printer, it is better you reduce the intervention rate for eavy card printing tasks, to be reduce as little as possible.
it is impossible to view the entire job queue from the web server or LAN.
so setup menu and fast scan so that they can return to their desk.
i believe i have answered your question.
thanks for using fixya.
6/13/2010 12:36:27 AM •
Panasonic...
Answered
on Jun 13, 2010
E02-02 - what does this error mean for a DP-C213?
E2-02 means there is an error with the lifting motor assembly for tray
#2. You will not be able to use your tray #2 until it's fixed. You can check
it, sometimes there's just paper clogged at the rear of the paper tray. Remove your 2nd tray to see if there is a paper clogged inside.
Otherwise the cover/case of the lifting motor is damaged and you will
need a service technician to fix and replace it.
5/7/2010 7:14:08 PM •
Panasonic...
Answered
on May 07, 2010
