20 Most Recent
Black & Decker TRO651 Toast-R-Oven Toaster Oven with Convection Cooking Questions & Answers
Top element not working all wires are connected
Very possible the element on top has a break some where but maybe small enough you cant see it or could be hiden. If you have access to a multimeter put it to ohms and with it unplugged from the outlet take the wires off the element and check the element itself if the multimeter reads OL the element is bad.
My TRO651 Toaster-R-Oven does not
May not be too hard to fix. On the thermostat, you will see 5 wires coming from it. black and white on top (leave those alone), and on the bottom of the switch, there are red white and blue wires.The white wire with the burnt connector(from use) is the problem. I had that switch apart, seen how it works. The 3 wires at the bottom (red, white, blue) is like a spst center off switch with white being the common center wire. Red is for oven, and blue is for toaster. After I rebuilt the switch the first time, and it happened again, I just bypassed switch by connecting that burnt bottom white connector, to the red timer wire connector. Oven will work, toaster will not. The oven turns off when timer runs out. Can also unplug or turn down thermostat all the way so it does not use much power when done using till timer runs out. If you have a spst(center off) switch, you can mount that too to the side panel if you find one rated for it. Just make sure the bottom white wire is used as the common center wire.B&D will not sell that switch that is broken. I tried that before I took that switch apart. Glad I did take it apart as I am sure their new switch would have failed quickly as well.
Doesn't bake anymore. Will toast
The main switch is probably fried.
http://www.google.com/url?sa=t&source=web&cd=2&sqi=2&ved=0CCQQtwIwAQ&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3D0H_2xkHX2MU&rct=j&q=dead%20B%26D%20toaster%20switch&ei=TDPsTfCzIsj40gHt_t20AQ&usg=AFQjCNH-29MMcdG4-dvG5BaUMoHwmdGJHw&sig2=TAo2lyiw4kl3sjH8n650vQ&cad=rja
http://www.google.com/url?sa=t&source=web&cd=1&sqi=2&ved=0CB0QtwIwAA&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DFpCEjqsz1Bo&rct=j&q=dead%20B%26D%20toaster%20switch&ei=TDPsTfCzIsj40gHt_t20AQ&usg=AFQjCNGFR3WEyLDELaHhTSilqPBn4KosFg&sig2=UMJZuhN7h7DYKTiCQb8Ubg&cad=rja
Describe your Black & Decker TRO651
The unit has a one year warranty from the date of purchase. If you're a little bit over the warranty, we'll still work with you on an exchange. The unit can not be fixed it has to be replaced. Please call our customer service line at 800-231-9786. I happen to work in their call center. :)
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
Black and Decker Extra Large countertop oven trips breaker
I work for Black & Decker customer service. Our phone number is 800-231-9786.
Sparks coming from any appliance or electronic device is very serious. Please call the above number sometime on Monday between 8:30 and 5:00 EDT. One of our customer service specialists will assist you with this matter.
allows you to make an informed decision as to how to proceed from here.
Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Light does not come on
see http://www.fixya.com/support/t153483-no_oven_but_still_toasts. the suggestion for thsi problem helped us withthe problem that you describe. Clean the contact after opening fromthe right side.
