20 Most Recent
Philips Senseo HD7832 Coffee Maker Questions & Answers
Lid is stuck shut on my senseo
I just had this same problem. The seal is stuck and might have coffee jammed in it. I unplugged it. Then I pushed down on the lid and pulled up at the same time. It opened for me. I hope this helps.
Senseo is not putting out the water
There is a possibility it just needs more water or it could be 'furred up' because it has not been purged or descaled for a long time. Fill up with water and place a large jug '500ml min' under and press both the single and two cup buttons at the same time. Refer to the user manual for the type of descaler to use.
Light keeps flashing and water will not heat
there is a float at the side of the machine by the water level, if the float gets stuck the red light will continue to flash even though water is present. Use a magnet on the outside of the machine by the water and float level and raise the float when connected to the magnet and the light will stop flashing red rapidly
How do you 'Calc Clean'?
Hello shid9
This is an easy fix. To decalcify your unit you need to make a water/vinegar solution. 2 parts water and 1 part vinegar. You might need to run two pots of the solution through if the first one is very cloudy. When done with that, rinse with 1 pot of fresh water. This should help remedy your calc problem. I hope this is helpful for you.
Happy brewing! NormanZ
Senseo 7814 does not heat water and red light keeps flashing
is the red light flashing as though not enough water, if so use a magnet to connect to the valve inside the machine, the valve can be found along the water level where the float is. what is happening is that the float is stuck. by connecting the magnet to the valve and very slowly moving the magnet along the water level, upwards the valve will follow and the water will begin to heat as the light changes to a slow flash, if it doesn't work try again as you have not connected to the magnet
Coffee is watery. Not sure if its the maker or
Hi. Who says to use vinegar. I wouldn't use that. Sounds like your pump is not pumping at right pressure. Vinegar can make the lime/calcium build up, break up into too large of pieces. which can block the pump. Descale solution breaks these deposits up. allowing it to be flushed from the system. Dazza REPAIRER
