20 Most Recent
Connex 4800-DXL 480-Channels Base CB Radio Questions & Answers
Connex 4300-400 how many amp can they pull
easy way to find out.. is use the wattage divided by the voltage used will give you amp draw.
so if you in a vehicle.. most are either 12-15 volts.
the radio in theory say its doing 400 watts.
400/12 = 33.3 amps
normal cb that can do 12watts your looking around 1-2amp draw.
When i turn on my connex 4800 dxl all that lights
The voltage regulator on the right side of the radio (with the parts side up ) is located in between the 2 side screw holes is ether bad or the legs are broke loose . it is a A1869 transistor.can be replaced with a A473 Transistor . Basically it's the same as a Galaxy Radio ,Ranger makes the boards for (RCI ,Galaxy , Connex , North Star ,Super Star, General Lee .) Hope this Helps.
I hope some one can
If it has a relay for the transmit, just tape on the relay when you key up and see if it is stuck.
How do peak and tune my 4300 dxl
modulation cut r249 & r246 these are limiters no limiters loud modu this radio is the same board as the 3300 connex
am low power adj vr 13 high power L 32 L 33
Owners manuel
What do you need the owners manual for but you can always google it out.
I think my connex 4800
Hi,my name is John. Welcome to FixYa. Turn your RF GAIN to MAX. Thanks for choosing FixYa. good luck....John
Swr will not go under 2.5 even with antenna adjusted up and down
if your swr is higher on 1 then on 40 then your antenna is electrically short and you have to lenghten the antenna.If it is higher on 40 then on 1 then it is long and you have to shorten it. If you have to make it longer then you may have to add a quick disconnect or a coiled spring to make it longer. To make it shorter all you have to do is trim a 1/4 in at a time off the antenna whip but you must keep checking the match until it gets down below 1.5 .
