20 Most Recent
Electrolux E30DF74PS Dual Fuel (Electric and Gas) Kitchen Range Questions & Answers
Oven door locked
Good Morning ljm_email, I am happy to assist you!
I understand the door of your Frigidaire range will not unlock. Here are a few simple troubleshooting tips that you need to take:
- First, locate CLEAR/OFF or CANCEL button.
- Then press button in for approximately 3-5 seconds.
- If that does not work, then reset your appliance by either unplugging it or flipping the household circuit breaker. It is necessary to wait roughly ten minutes and then turn your range on.
- If the abovementioned steps do not resolve your issue, you may wish to contact a professional as your range may possibly have a defective door lock assembly, wiring, or communication problem with the EOC (Electronic Oven Control).
Best of luck!
Electrolux oven f10 error code
Hello Mary, thank you for allowing me to assist you!
Typically error code F10 indicates your range has detected an issue with the runaway temperature (overheating). Let's try reprogramming your appliance by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn your range on. Usually this will clear most false error codes. If issue persists, at this moment I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps!
11/22/2013 12:06:19 PM •
Electrolux...
Answered
on Nov 22, 2013
Oven door lock does not unlock
Hi
Thanks for using FixYa. There is
an over-temperature switch built into the electrical panel of the oven.
Resetting this switch might solve the issue.
To reset it: Turn off the power. Open the door (if door is locked, turn the
power back on and gently try pulling the door every few seconds as the locking
mechanism cycles until it is unlocked). Remove the 3 screws below the control
panel (screws point upwards, with the head just inside the oven). Pull off the
face of the control panel. Let it dangle by the wires so that you have access
to the space behind it.
Within the electrical enclosure exposed by removing the control panel, look for
a small silver and black device with 2 wires attached to the back. The device
is about .5" wide by 1" long and is attached with 2 screws to the
sheet metal on the bottom of the electrical enclosure.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
12/10/2011 10:10:04 PM •
Electrolux...
Answered
on Dec 10, 2011
E30DF74EPS Model
When turning left dial
Convection roast and Clean lights flash and beeps.This problem is related to " OPEN TEMPERATURE PROBE"------- The oven temp sensor needs to be replaced.
The error light blinking sequence is mentioned on the page number 43 of the manual:-- Click the link below:---
http://67.199.110.146/docs/manual/51829_en.pdf
To check the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
To order this part,click the link below:---
http://www.repairclinic.com/PartDetail/Oven-Sensor/316217002/1015027
This should help.Thanks.Helpmech.
Electrolux glass cook top model PLEC30SS980CB says ER on one burner.
When an Electrolux glass cooktop displays the "ER" error code on one burner, it typically indicates an issue with that specific burner. Here are a few troubleshooting steps you can follow to try and fix the problem:
1. Turn off the power: Start by turning off the power to the cooktop at the circuit breaker. This ensures your safety while working on the appliance.
2. Check for debris or obstructions: Inspect the affected burner for any debris, food residue, or obstructions. Clean the burner thoroughly with a soft cloth or sponge, ensuring there is no buildup that could be causing the error.
3. Reset the cooktop: After cleaning, reset the cooktop by turning the power back on at the circuit breaker. This may clear the error code and allow the burner to function properly again.
4. Check the wiring: If the error persists, there might be a wiring issue. In this case, it is recommended to contact a professional technician or the Electrolux customer service for assistance. Working with electrical components can be dangerous, so it's best to have a qualified professional handle the repair.
Electrolux customer service can provide further guidance and troubleshooting steps specific to your model if needed.
Electrolux range touch pad for model EW30ES6CGS4 willl not shut glass burner
If the Electrolux range touch pad for model EW30ES6CGS4 is not shutting off the glass burner even when it shows that it is off, there are a few troubleshooting steps you can try:
- Check for any physical damage: Inspect the touch pad and the burner area for any visible damage, such as cracks or signs of overheating. If you notice any damage, it may indicate a need for repair or replacement of the affected parts.
- Power cycle the range: Turn off the range by disconnecting it from the power source or by turning off the breaker for a few minutes. Afterward, reconnect the power or turn the breaker back on and see if the touch pad responds correctly.
- Check for error codes: Some range models have error code displays that can provide information about specific issues. Refer to the user manual or manufacturer's website for instructions on how to interpret error codes, if applicable. This may help identify the underlying problem.
- Perform a factory reset: Look for instructions in the user manual on how to perform a factory reset for your specific range model. This can sometimes resolve software glitches or settings issues that may be affecting the touch pad's functionality.
- Contact customer support: If the above steps do not resolve the issue, it is advisable to contact Electrolux customer support or schedule a service appointment with a qualified technician. They will have the expertise to diagnose the problem accurately and recommend appropriate solutions or repairs.
When reaching out to customer support or a technician, provide them with specific details about the issue, the model number (EW30ES6CGS4), and any error codes or messages displayed on the touch pad. This information will assist them in providing you with the most effective support or service.
How to fix an error E 15 code on electrolux induction range
Thank you for your inquiry, Carol!
From what you have described your Electrolux range is displaying an error code of E15. I see you have reset your breaker and continue to receive the error code. The error code E15 means that your ESEC (Electronic Surface Element Control) test failed this could be a problem with your relay board or UIB (User Interface Board). When you reset your breaker did you leave it off for at least ten minutes? That is the best way to reset your range. You may need to seek assistance from a professional technician for proper diagnosis and repair. This will help you to avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
Why do I get E 21 message on my Electrolux slide in range Model EW301S6CjSc which has frozen the stove top
Thank you for your post, Sandra Gee!
Based off the information you have provided an "E21" error code is displaying on your Electrolux range. Typically, an "E21" stands for a communication failure between the EOC (Electronic Oven Control) and the ESEC (Electronic Surface Element Control). I would suggest performing a reset on your range and you can do that by disconnecting the power from it for ten minutes. The best way to disconnect power is to flip the household circuit breaker. If you continue to have an issue with an "E21" error code I would have a professional technician perform a diagnosis on your range to help repair it properly. Hope this is helpful. -Matt
