20 Most Recent Panasonic NNH965BF Microwave Oven Questions & Answers
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
www.panasonic.com/repair
Welcome to Panasonic Online Repair
Panasonic... | Answered on Mar 24, 2014
The problem is the release spring is broken or the button is sticking, pick up a small can of electronic cleaner attach straw and spray into the button crevis to break down the crud, grime, and dirt this should help release the mechanism.
Panasonic... | Answered on Apr 23, 2012
hi,
look in the back through the grille with a flashlight to see if the cooling fan is running, you should feel a slight draft there too. if not running take the cover off and oil the magnetron cooling fan with 3 in1 sewing machine oil. oil it on both sides of the motor so its saturated. if it does it again you will have to order that motor. probably at panasonic.com or searspartsdirect.com. be careful inside the microwave with the cover off, avoid the red high voltage wires. use gloves if necessary. panasonics are a pretty good oven, worth fixing..
jm
Panasonic... | Answered on Apr 25, 2011
They say the burned smell comes from a diode that has melted, which breaks a circuit within your microwave. Most microwaves have no user-serviceable parts. Best to play it safe and have a tech look at it, or replace it.
Panasonic... | Answered on Feb 28, 2011
According to the manual this is how to set clock.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
The colon symbol (:) will flash.
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
If you need the manual it is on link below.
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
Good Luck
Panasonic... | Answered on Nov 08, 2010
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Panasonic... | Answered on Oct 01, 2010
your mag has gone bad and possible that the inverter board as well, not really worth the hassel
Panasonic... | Answered on Feb 06, 2010
Never disassemble. Capacitors in over can kill if they discharge while working on oven even if oven is unplugged, yes. Unplugged
Panasonic... | Answered on Sep 15, 2019
H87 is a power supply issue.
Contact a Panasonic repair agent.
Panasonic... | Answered on Aug 26, 2019
What does the start button have to do with opening the door?
Panasonic... | Answered on Aug 17, 2019
Panasonic NNH965BF Microwave Oven Logo
26 questions posted
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Microwave Ovens
Most Popular Question
panasonic nnh965bf microwave starts but
  • Microwave Ovens
