20 Most Recent
Acer Aspire (AST180-US340B) PC Desktop Questions & Answers
Prinwhat port do I use to hook up printer to Aspire AST 180 UA 381B
Your printer should connect up to any USB port (small rectangular opening near where the monitor and keyboard plug in (same type of opening). If your printer is so old it has a cream colored cable and one end that has 25 pins sticking out of it, you will save money by just buying a new $30 printer. Anyhow, newer printers connect with a thinner cable like your mouse cable, is flat / rectangular on one end, and is kind of tall-igloo shaped on the other end.
If you go for the new printer, I used to hate Epson, but bought one December 2013, and it uses a lot less ink than my older Canon or HP printer. I bought one with a touch screen panel and it can print from my smart phone and all the PCs without connecting any wires. The one I bought was about $100.
Your PC has a very new wired connection (Gigabit LAN) for your home network; but unfortunately does not come with a built in wireless card. If you are also unfamiliar with the LAN cable, it is an RJ45 connector. Looks just like a phone cable, but 50% wider.
If this is unclear, feel free to add more detail or let me know what you need more clarification on.
All the best to you,
Kerry
Printer port
The printer port is the big pink connector on the rear panel.If it don't work try an USB printer or a USB to LTP adapter
My computer monitor is black
PC running? Light in house OK? Then check video cable and power cord on
the screen. If the problem persist try with an other screen.
Monitor Going To Sleep
It means your system is not able to Provide Display to your monitor. You may try the following steps to troubleshoot display problemHere are the Few steps which you can do by yourself to bring back the display(if your Luck is GOOD:D )1step-Open the Case and check if RAM is properly fix.. just take out the RAM, Clean it and fix it back properly.2step- search for CMOS battery on the motherboard.. just remove it for 10-20 seconds and fix it back.3-step Remove the CPU Fan and CPU and Fix it properly.It happen when you shift your PC from one place to other.ALL the best and if it works than please give ranking.
Monitor Going To Sleep If Powered On
Ast180-ua381 memory updrade no post
Well, the maximum memory capacity is showing as 4GB with 512MB factory installed. So, what kind of memory are you installing? Are they PC2-6400 DDR2 SDRAM DIMMS? Are they EEC or NON-EEC? The same RAM card has to be installed in the paired slots, but they also have to be at a speed the motherboard can use (PC2-6400 for example).
Ican`t open mails always freezing
Many things could cause your computer to run slow and experience freezing. Most commonly these problems come from malware and broken registries.
A simple solution to this problem is to use a registry cleaner and antivirus;
- CCleaner is a free system optimization and privacy tool that erases Internet history and other unused files, and cleans up orphaned registry entries. It is the number-one tool for cleaning your Windows PC. It protects your privacy online and makes your computer faster and more secure. Easy to use and a small, fast download.
- Use your antivirus program to perform a full system scan for malicious software.
If you feel that your antivirus is inadequate, then I recommend you use Microsoft Security Essentials. It is a free anti-malware solution that helps protect you against viruses, spyware, and other malicious software.
I have an acer aspire
download the Kespersky Rescue CD, It is a free Linux based live booting OS, burn the file on the cd, put it in your drive restart the computer and boot from the disk, it will have directions on how to run from there.
I would suggest you install Linux Mint 10, a free operating system.
Without the restore disks,you would have to buy a new Windows CD. Have a friend burn an ISO image of Linux Mint. Just go to
www.linuxmint.com, and there are lots of helpful tips there on how to install. Linux Mint has a similar feel to Windows, so it should be good!
I forgot my bios password,
A. By Removing the
CMOS Battery:
Almost all motherboards use a small coin sized CMOS battery to store
all BIOS settings along with the password. To reset the password, unplug
the PC, open the cabinet and remove the CMOS battery for approx. 15-30
minutes and then put it back. It'll reset all BIOS settings as well as
the password and you'll need to re-enter all settings.
If it fails, then try to remove the battery for at least one hour.
B. By Using the
Motherboard Jumper:
Almost all motherboards contain a jumper that can clear all CMOS
settings along with the BIOS password. The location of this jumper
varies depending upon the motherboard brand. You should read your
motherboard manual to check its location. If you don't have the manual
then look for the jumpers near the CMOS battery. Most of the
manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
I created more user accounts
go my computer,drive c,documents and settings,then check on each profile which one hosts your data,it might be the profile name is changed but the rights are of the admin
