20 Most Recent JVC NX-PS1 Shelf System Questions & Answers
I have a jvc nx-ps1 and im getting a power error
Had the same problem, unit came on with "Power Error" for a few seconds then shut down. Checked the JVC power supply and had the correct 23.5 VDC at the pin jack. Re-inserted the power jack and quickly kept randomly pushing the front play, stop, FF, Vol + - and rewind buttons on the unit. It came on and is working fine. Guessing it's an internal software or component issue sensitive to our constantly fluctuating and failing commercial AC service
1/15/2024 10:55:17 AM • JVC NX-PS1 Shelf... • Answered on Jan 15, 2024
0answers
0answers
JVC NX PS1 - No sound output when connected to PC
use the aux in front and connect to headphone output on laptop or desktop
11/6/2008 3:11:40 AM • JVC NX-PS1 Shelf... • Answered on Nov 06, 2008
Does the JVC UX-A4 have aux inputs for a separate turntable to play through amp?
It does have an aux input with two levels but this isn't suitable for a turntable. A suitable input should have RIAA correction with a sensitivity of just a few millivolts for a magnetic cartridge. Instruction manual can be found on the link below... http://resources.jvc.com/Resources/00/00/90/LVT1519-001C.pdf
3/7/2024 10:42:20 AM • JVC Audio... • Answered on Mar 07, 2024
I have jvc th a75r hardret plz help
Here is the user manual; https://www.manualslib.com/products/Jvc-Th-A75r-252593.html
3/4/2024 7:47:22 AM • JVC Audio... • Answered on Mar 04, 2024
I have a JVC RX-501 reciver and 2 speakers Sony(200W). I start the reciver and After 3-4 seconds it S make a sound like" bun bun " that S all... After 1-2 minute again..
The sound you're hearing could be due to a variety of reasons, such as a loose connection, a malfunctioning component, or a power issue. Here are some steps you can take to troubleshoot the issue: Check the speaker connections: Ensure that the speaker wires are properly connected to the receiver and the speakers. Make sure that the positive and negative terminals are correctly aligned. You can also try disconnecting and reconnecting the wires to ensure a secure connection. Check the power source: Ensure that the receiver is plugged into a working power outlet and that the power cord is securely connected to the receiver. You can also try plugging the receiver into a different power outlet to see if that resolves the issue. Check the volume level: Ensure that the volume level on the receiver is not set too high. High volume levels can cause distortion and other issues. Reset the receiver: Try resetting the receiver to its default settings. To do this, turn off the receiver and unplug it from the power source. Wait for a few minutes, then plug the receiver back in and turn it on. If these suggestion don't help, you may have to seek professional repair.
2/2/2024 9:08:57 PM • JVC Audio... • Answered on Feb 02, 2024
1997 JVC RC-X270 does not read CDs
A bit of basic knowledge is required first; Insert CD, the first thing the processor expects is to scheive Focus. When Focus is acheived, the Spindle Motor will turn. Either the Laser cannot Focus or there is an issues with the Spindle Motor. Which is it ... if you know, then you will know which part or board has the issue.
1/29/2024 6:36:28 PM • JVC Audio... • Answered on Jan 29, 2024
JVC MX-GC5 3-CD/AM/FM shelf system with USB. What makes my CD motor not working it's not playing any CD's?
Question edited for a lot more clarity and toss in a load of CAPS. Can you hear the CD Motor spinning? If so, probably this https://www.fixya.com/support/r29927004-dvd_player_or_cd_player_not_reading If not, the CD Unit has failed, or the power supply to it. A JVC Service Centre should be able to fix it. ..
1/16/2024 11:43:06 PM • JVC Audio... • Answered on Jan 16, 2024
JVC FS-2000 radio. How do I turn off the alarm on it please?
Question edited for clarity, toss in some CAPS, add the Magic word. Strangely there is no owners manual but there is a Service Manual for it. It appears that it is actually a 'JVC FS-2000GD'? Normally turning off the alarm just requires pressing the Alarm Set button one more time to toggle it off. Or you can disconnect it from the mains, remove any back up batteries if it has them and it will reset everything. Then set the time.
JVC FS-2000GD Service Manual download, schematics ...
Elektrotanya https://elektrotanya.com > download ยทTranslate this page Download JVC FS-2000GD service manual & repair info for electronics experts.
12/31/2023 6:12:21 AM • JVC Audio... • Answered on Dec 31, 2023
User manual for JVC CA-D8T in english
Download service manual. Operating instructions are also given in english. JVC CA-D8T SM Service Manual download, schematics, eeprom, repair info for electronics experts (elektrotanya.com)
12/28/2023 12:02:50 PM • JVC Audio... • Answered on Dec 28, 2023
JVC UX-P550 Music Unit. Do I need a remote for full user ability?
Question edited for clarity and toss in some CAPS.. Yes, it looks like you do. Replacement Remotes https://www.google.com/search?q=jvc+ux-p550+replacement+remote
JVC UX-P550 Instructions Manual
ManualsLib https://www.manualslib.com > ... > UX-P550 View and Download JVC UX-P550 instructions manual online. JVC Micro Component System Instructions. UX-P550 stereo system pdf manual download. ..
11/3/2023 5:18:04 PM • JVC Audio... • Answered on Nov 03, 2023
JVC THG30 1000-Watt Home Theater System. There is no music coming out. Any suggestions? Please help.
Question edited for a lot more clarity. All questions need 'make model (what it is)' please. Question moved from Computers. Troubleshooting. Check all the wires at the back. https://www.google.com/search?q=JVC++th-G30+no+sound ..
8/20/2023 2:19:02 AM • JVC Audio... • Answered on Aug 20, 2023
JVC NX-PS1 Shelf System Logo
9 questions posted
Popular Products
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Audio Players & Recorders
Most Popular Question
jvc nx ps1 im getting power error
  • Audio Players & Recorders
