20 Most Recent
American Audio DCD-PRO310 Questions & Answers
Problem finding tracks
Try bunring a cd at the slowest possible speed and see if it helps. Also I would try a different burning software than what you are using now. (Even if it is iTunes or Media Player and if your already using these try roxio or nero instead).
I'm have'n a problem
You should be connecting this product to a dj mixer because this unit has no internal mixer.To accomplish this you should connect the two outputs lines for channel 1 from this cd player to the two input lines on channel 1 of your mixer and the same for channel two, connect channel two from your cd player to the channel two input on your mixer and then hook your mixer to a amplifier, then amplifier to speakers. D.J Fire in Louisiana***
American audio MCD 510 will not read Cds
what is this thing, part of a car? no
what means" Read CDs????"" << I cant' guess. it.
did that mean analog works but the digital jacks are dead? only?
it is HOME Stereo Dual CD deck player.
analog RCA out and digital. out x2. S/PDIF digital output for each player
Do not set the AC line voltage on REAR wrong (0r smoke time)
plays CD_DA disks and some MP3 files. on CD
the clicker needs new batteries. (repeats often)
we can not see your display to see things good or wrong.
even both. hummmm we are blind here and seeing is first.
first learn this,
1: test any deck like this using CD_DA (digital autio) disks using only store bought (brick) real music disks,
this is test #1 and they must play on both channels L/R
RCA OUT JACKS. TO THE AMP, RECEIVER, OR HEAD..
TEST
#2 A MP3 DISK (JUST FILES NO FOLDERS)
LIKE STONES.MP3. ETC
BURNED SLOW TO CD-R (DASH NOT PLUS)
use only normal Mp3 encoding not wild.
encode (44.1 kHz at normal pitch)
2005 made deck I think or older. (oldest review says)
the manual is free online
in the blind
we can not see what media you use or if MP3.
or how rear is connected and to what AMP.
nor if RCA or S/PDIF digital output fails 1 or both or all channels.
I HAVE BEEN GIVEN THE
I have scowered the web and this is as close as I can get - it looks to be EXACTLY the SAME as the 1000 - no difference except in the power put put.
Please rate me up all the way if I helped you it really makes my day.
Thanks,
Gary Rice
