20 Most Recent Sunpak PZ40X II TTL Flash Questions & Answers
2answers
Sunpack pz40X II flash - compatible with Nikon D40?
hai i think u told only sometime....
may b ur settings are not rit in the cam.
11/22/2009 9:50:55 PM • Sunpak PZ40X II... • Answered on Nov 22, 2009
Does someone have a manual for the Sunpak Auto 355af thyristor flash?
Hey there, I had one a couple of months back, but unfortunately I got rid of it since I no longer use it. But, you can certainly buy one online. Check out Amazon or Newegg. Good luck!
9/24/2020 8:12:08 PM • Sunpak Cameras • Answered on Sep 24, 2020
Hi, I have a Sunpak Auto 555 that can be turned on but refuses to fire! Is is possible that I need to change the flash tube? Does anyone know where to buy one?
When it is not triggering either Tube is dead or Trigger circuit has a problem. You can get junk flash from Ebay.
12/6/2017 1:20:57 AM • Sunpak Cameras • Answered on Dec 06, 2017
What does nE 02 on my Sunpak PZ42X flash mean
This should be covered in the manual - it is probably an error message of some description.
10/30/2017 12:12:01 PM • Sunpak Cameras • Answered on Oct 30, 2017
Sunpak tr-2000 flash repair/new Nicad battery
Sevice.
6/3/2017 2:38:09 AM • Sunpak Cameras • Answered on Jun 03, 2017
I bought the Sunpak PZ58X for Nikon. It flashed twice and after that it is not flashing.
Have you tried other flashguns ? Does this unit work on test ?
11/15/2016 12:46:47 AM • Sunpak Cameras • Answered on Nov 15, 2016
Hello there, is it possible to change a bulb on a Sunpak auto 2000 DZ, I think I burnt out the flash
I think you would need to send it for repair but be aware of the cost of repair as apposed to a new unit.
3/11/2016 8:02:02 PM • Sunpak Cameras • Answered on Mar 11, 2016
Can i use an old sunpackflash as slave voor nikon 800
Yes you can. All you need is a small inexpensive slave unit.
1/29/2016 3:27:00 PM • Sunpak Cameras • Answered on Jan 29, 2016
I need a operating manual for Sunpak Auto Thyristor G4500DX Flash gun only
I found this for a Sunpak flash which is similar to the G4500dx: Reading from the "auto555/G4500DX" Manual, you need to: 1. Slide the Film Selector to desired ISO - (that is the same as your camera ISO used - so, make sure you turn Off the Auto ISO feature if your camera has one). 2. Slide the Mode Selector to "A" (Auto position). This will be Auto Thyristor mode on the flash. 3. Slide the Auto F/stop Selecct Know to desired lens openning - ( so use your camera in Aperture priority mode, more in Manual to prevent changes in the camera aperture value during shooting) Shoot, and be happy with well exposed pictures by the Auto Thyristor features of the Sunpak 555 flash. The Sunpak 555 works great with Nikon D50, D70 cameras, as you can synchrinize flash practically at all shutter speeds. Excellent for sunny days to get narrow DOF, yet get any ambient light level contribution as desired. For other cameras, make sure (watch out for) that Aperture Priority mode does not use shutter faster than the camera max X-sync speed - so Manual camera mode could be a better choice for a novice photographer. In the manual there is also a list of accessories for various brand cameras, How to use Power Ratio in Manual mode, some advice on using wide lenses, how to care of your 555, and Specification section. Minimal flash duration is 1/450 at full power, so you can safely use Auto Aperture up to 1/500 sec. Flash duration decreases with lower power setting, or lower auto mode need for poser, and the shortest flash duration is 1/17000th sec.
1/29/2016 3:26:05 PM • Sunpak Cameras • Answered on Jan 29, 2016
Digiflash 3000 will not flash even when testing. I hear it warm up, ready light comes on, but nothing.
These are not that expensive to buy, the problem is that the parts and service are more than a new one. In any case they use high voltage and you have to use special tools to measure and service the flash circuit. IT might be the flash tube is bad, the trigger circuit is bad, the capacitor is bad etc.
4/18/2015 3:07:28 PM • Sunpak Cameras • Answered on Apr 18, 2015
My sunpak digiflash 3000 won't fire, or do anything when pushing the test button, it has new batteries and the flash ready light is on
My sunpak digiflash 3000 will not flash at all even when pushing test button. It warms up, ready light comes on but no flash.
4/17/2015 11:57:41 PM • Sunpak Cameras • Answered on Apr 17, 2015
How long do i charge a sunpak nc 510 rechargeable using a QBC-5 CHARGER
Sunpak uses different power sources on their high-power handle mount (a.k.a. hammerhead) flash guns. The most common is the battery basket that holds 4 or 6 AA or C batteries depending on the type of the unit. One can insert Nickel-Cadmium or Nickel-Metal-Hydride rechargeable batteries instead of the primary cells, this way reducing the "consumables" costs at the expense of the smaller number of flashes per battery set. (Actually, NiCd or NiMH cells would probably give smaller number of flashes compared with the alkaline cells, but the recycle time between the flashes can be shorter. The reason is that at charging the flash capacitor inside the flash current counts more than voltage. Sunpak sells Ni-Cd battery packs named CL-2 for their flashes that utilize 6 AA-cells, and CL-3 for their 622 series (4 C-cells). The charger for these is the QBC-5. It recharges the exhausted batteries in 3 hours. As a solution assuring the shortest duration between flashes Sunpak offered the Powerpak, a shoulder holster that held a dry (non-rechargeable) battery of 510V, it charged the flash capacitor directly, omitting the transistor inverter in the flash body. As such battery became obsolete, the Poverpak has been superseded with the NC510 and later the TR-II PAK, which utilizes 10 Ni-Cd rechargeable batteries as a power source, and a powerful (more capable than the one in the flash) transistor inverter. NC510 and TR-II PAK use the same connection to the flash and the same outlook as the original Powerpak but, being rechargeable, are more economical. QBC-5 also serves a charger for the NC510 and TR-II PAK. You may ask, how the same charger can be used for 4, 6 and 10 cell NiCd packs. Well, the charger is specially designed for that, although charging time differs at the different battery packs. The NC510 and the TR-II PAK needs 10 hours to be recharged, when exhausted. The best way to avoid damages (overcharging degrades NiCd and NiMH cells) is to check temperature of the batteries. Charging must be cut off if the battery becomes hotter than 45 ?C (115 ?F). If after 10 hours of charge the NC510 does not power (the otherwise working) flash, then it must be serviced. Replacing the batteries is an easy job that can be done at home, with some soldering skills; NiMH cells with solder tabs are available at many web-based supplyers. Don't solder the cells directly, heat damages them. Avoid touching parts inside, when the pack is turned on: electrocuting is fully possible. Better find a professional, if you are not familiar with the electronics.
2/1/2015 8:19:59 PM • Sunpak Cameras • Answered on Feb 01, 2015
How long does it take charge the sunpack 510 batt using the qbc-5
Hi, Sunpak uses different power sources on their high-power handle mount (a.k.a. hammerhead) flash guns. The most common is the battery basket that holds 4 or 6 AA or C batteries depending on the type of the unit. One can insert Nickel-Cadmium or Nickel-Metal-Hydride rechargeable batteries instead of the primary cells, this way reducing the "consumables" costs at the expense of the smaller number of flashes per battery set. (Actually, NiCd or NiMH cells would probably give smaller number of flashes compared with the alkaline cells, but the recycle time between the flashes can be shorter. The reason is that at charging the flash capacitor inside the flash current counts more than voltage. Sunpak sells Ni-Cd battery packs named CL-2 for their flashes that utilize 6 AA-cells, and CL-3 for their 622 series (4 C-cells). The charger for these is the QBC-5. It recharges the exhausted batteries in 3 hours. As a solution assuring the shortest duration between flashes Sunpak offered the Powerpak, a shoulder holster that held a dry (non-rechargeable) battery of 510V, it charged the flash capacitor directly, omitting the transistor inverter in the flash body. As such battery became obsolete, the Poverpak has been superseded with the NC510 and later the TR-II PAK, which utilizes 10 Ni-Cd rechargeable batteries as a power source, and a powerful (more capable than the one in the flash) transistor inverter. NC510 and TR-II PAK use the same connection to the flash and the same outlook as the original Powerpak but, being rechargeable, are more economical. QBC-5 also serves a charger for the NC510 and TR-II PAK. You may ask, how the same charger can be used for 4, 6 and 10 cell NiCd packs. Well, the charger is specially designed for that, although charging time differs at the different battery packs. The NC510 and the TR-II PAK needs 10 hours to be recharged, when exhausted. The best way to avoid damages (overcharging degrades NiCd and NiMH cells) is to check temperature of the batteries. Charging must be cut off if the battery becomes hotter than 45 ?C (115 ?F). If after 10 hours of charge the NC510 does not power (the otherwise working) flash, then it must be serviced. Replacing the batteries is an easy job that can be done at home, with some soldering skills; NiMH cells with solder tabs are available at many web-based supplyers. Don't solder the cells directly, heat damages them. Avoid touching parts inside, when the pack is turned on: electrocuting is fully possible. Better find a professional, if you are not familiar with the electronics.
2/1/2015 6:25:28 PM • Sunpak Cameras • Answered on Feb 01, 2015
Sunpak PZ40X II TTL Flash Logo
Popular Tags
1 questions posted
Top Sunpak Cameras Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
View Most Popular
Sunpak Cameras
  • Sunpak Cameras
Most Popular Question
sunpack pz40x ii flash compatible nikon
  • Cameras
