20 Most Recent Samsung HL-S5688W 56 in. HDTV Television Questions & Answers
0answers
I have a 5 year
Be the first to answer 2/11/2018 10:09:03 PM • Samsung... • Posted on Feb 11, 2018Be the first to answer
No Sound
Go to settings speakers and check unless cables faulty hdmi or scart connections
5/31/2014 2:16:52 AM • Samsung... • Answered on May 31, 2014
Picture breaks up sometimes
check your cable connections from cable box,satellite box, etc... cables need to be tight, not just finger tight.
1/3/2011 10:29:00 AM • Samsung... • Answered on Jan 03, 2011
Cannot get TVGuide Onscreen Updates on Samsung HLS5688W
By that, do you mean that when you open the guide up, it updates? If so, try waiting for a while. If that doesn't work, try taking it to a shop.
4/2/2010 2:59:58 AM • Samsung... • Answered on Apr 02, 2010
2answers
Where is the fan located and what is the check procedure?
remove the back cover u will see the fans one for the ballast and the other for the lamp
1/8/2016 2:37:04 AM • Samsung HL... • Answered on Jan 08, 2016
Replaced lamp now lamp light keeps flashing still also the stand by temp light flashes
Sounds like a door switch is not making proper contact--or has been damaged. Check the lamp door switch and see if it is properly seated and the pin on the door is hitting the leaf of the switch.
11/26/2014 4:13:19 AM • Samsung HL... • Answered on Nov 26, 2014
Samsung HL-85887W (HL556887WXLXAA). TV picture is dimming and loud hum from lamp area. This TV went through 2 lamps during warrenty period. I understand there are several lamp numbers and would li
You need a color wheel--common on these sets. Get a real phillips bulb and you should be set for awhile. The cheap generic bulbs are fine to get you through a few MONTHS....but NOT much longer. . An E22H-120/132 watt lamp is correct--and if you can replace just the bulb-(NOT hard at all to do) it will save you a LOT of money.
11/26/2014 3:50:14 AM • Samsung HL... • Answered on Nov 26, 2014
Samsung dlp dnie
just from personal exp the easiest thing to do may fix or at least make it better. if u see puffed and leaky caps on power supply replace capacitors. if really dusty clean. both previously mentioned and both helped me. my tv was completely dead and replacing caps got it to power back up and work. it takes two trys to come on but works great so far. then i cleaned every nook and cranny with a small vacuum hose and different size/angle brushes that could be attached to hose. i only took out the psb board with caps and didnt touch anything in there that i could mess up. just cleaning helped enhance the colors. right now this is the best picture ive had on a tv and it was completly dead when i got it.
7/30/2014 1:53:39 PM • Samsung HL... • Answered on Jul 30, 2014
After replacing a dlp chip have a green color on screen
Check all your input cables & be sure they are snug on both ends, also check all your wiring connections inside the TV. you may have not gotten something back correctly or properly.
7/25/2014 12:27:17 AM • Samsung HL... • Answered on Jul 25, 2014
Samsung HL72a650 tv power cycles
EURO STAR LCD TV 32" BLANK PROBLEM
1/23/2014 7:22:25 AM • Samsung HL... • Answered on Jan 23, 2014
0answers
SAMSUNG TV HL-85687W picture is dim
(Please check your model number - it appears to be incorrect, I believe it's HL-S5687W) 1) How old is the lamp? (how many hours on it)2) Is the lamp an original equipment lamp, or aftermarket?It's either the Lamp itself (it's not common for a sudden reduction in brightness), -or- the Lamp Ballast has gone bad. This is the power source for the Lamp, and although they usually die completely when they do go, sometimes they will act just as you have described... they fail into a "low power" mode.If the lamp IS an original mfr lamp, and if it's nowhere close to being near "end of life", then I'd say it's likely the Ballast.Prices for the original Samsung lamp run around $100 onamazon and others.The Ballast p/n BP47-00037A has a cost of around $50 to $100 online. Google those p/n in "Shopping"The Ballast can be replaced without great knowledge, but will require some dis-assembly, and CARE.WARNING - Dangerous, and even lethal voltages are present inside your TV set. Do not attempt this unless you are trained in these kinds of repairs. Leave the TV unplugged for several hours (or preferably a full day) before attempting such repairs.
1/12/2013 9:31:00 PM • Samsung HL... • Answered on Jan 12, 2013
Whats the reset code for a samsung tv hl4667w
as far as I know that set does not have a lamp timer to reset.
9/4/2012 1:36:12 PM • Samsung HL... • Answered on Sep 04, 2012
Samsung HL-S5688W 56 in. HDTV Television Logo
Popular Tags
6 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
HL Samsung
  • HL Samsung
Most Popular Question
no sound
  • Televison & Video
