20 Most Recent
Onkyo HT-SR700 System Questions & Answers
Onkyo HT R520 Home Theatre receiver/amplifier
I had the same problem too. All functions seemed operational but I could not get any sound out of my unit. I took my HT-R520 (4yr Old) to the Onkyo Service center in Denver Colorado (DTS). I paid out $50.00 to have them diagnois the problem. I was hoping that they would listen to me and the info I found via fixya user jaf323 and fix the problem for $50.00. Not....they ignored me. They told me it was my power supply and it would be $250.00 to fix the problem. Sooo, I decided investigate the problem myself. After finding an Okyo schematic free online for the 600 model which is similiar to the HT-R520, I was able to find the L7002 coil. I took my DVM to all of the coils I could get to labled 2R2 on the large horizontal PWA on the right side of the unit as you look at the front panel and sure enough, the L7002 coil was "open". All of the other coils (approx 4) showed a resistance of about 0.3MOhm. I pulled off the bad coil and swapped it out with same coil marked 2R2 from the headphone PWA using a tweezer soldering iron. I am a novice when it comes to electronics. This was a simple fix. BTW the little coils are about 1/8" x1/8" - little guys.
Onkyo HT-R520
Hello the HT-R520 is the model of the receiver that is part of the HT-S770 package. I suggest that you check the speaker settings. Check the level of the center speaker. If you need assistance please contact Onkyo at 800-229-1687 option #3. Thank you, Onkyo USA
Onkyo HT-R520 no sound
i did a factory reset on mine. it had the classic problems. no sound from any input except the tape input. after i did a factory reset they all seem to work.. we shall see for how long...
No sound it last night
have all the speakers been reconnected?
if so, there may be a blown output fuse inside the reciever.
Problem with Onkyo HT-SR700
Can you explain how you have the DVD player connected to the reciever and what the label on the jacks read on each.
0-83 error on onkyo tx nr 555
The 0-83 error indicates a problem with the firmware update.
Try resetting the receiver's BIOS by following these steps2:
Unplug all cables
Un-Power the receiver
Power the receiver
Before the receiver gets into the "Enter for updating" message, press Tone + CBL/SAT + ON/STANDBY. This will show you either the volume numbers or get you into settings of the receiver's speaker configuration.
Press CBL/SAT + ON/STANDBY. This will clear the BIOS and show a "Clear" message on the display. Wait until you hear a couple of clicking sounds for the receiver to turn on and off the power.
TX-NR555 Owner's Manual - Onkyo Product Support (onkyousa.com)
Onkyo nr 555 stuck on recovery:NET
Hello
Did you update the AVR over the internet?
If so the device wont work anymore.
You need to service the device in a nearest Onkyo service department.
Regards
Onkyo powered subwoofer SKW-791
Oknkyo SKW-791 has build in amplifier. So it can be connected through Line Out Connector of sansui amplifier. If speakers out is connected with subwoofer, the circuit board in subwoofer will be blown.
What's the error M1.04/19912A50?
The error code M1.04/19912A50 on your Onkyo AV receiver HT-R398 typically indicates a firmware or software-related issue. To resolve this problem and reset your receiver, you can follow these steps:
- Power Cycle the Receiver:
- Turn off the receiver and unplug it from the power source.
- Wait for about 10-15 minutes to ensure that all internal components have fully powered down.
- Plug the receiver back in and turn it on.
- Factory Reset:
- If the error persists after power cycling, you may need to perform a factory reset to restore the receiver to its default settings. Note that this will erase all your custom settings, so make sure to back up any important configurations if possible.
- To perform a factory reset, refer to your receiver's user manual for specific instructions. Typically, this involves pressing and holding specific buttons on the front panel while powering on the receiver. The exact combination of buttons may vary by model.
- Firmware Update:
- Ensure that your receiver's firmware is up to date. Visit the Onkyo website and check if there are any firmware updates available for your HT-R398 model. If updates are available, follow the provided instructions to update the firmware.
- Contact Customer Support:
- If the issue persists after trying the above steps, it's a good idea to contact Onkyo customer support or visit their official support website. They may be able to provide specific guidance or solutions for the error code you're encountering.
Remember to consult your receiver's user manual for model-specific instructions, as the steps to reset or update firmware can vary between different Onkyo models. Additionally, be cautious when performing a factory reset, as it will erase all settings and return the receiver to its default state.
