20 Most Recent Hannspree (K206-10U1-005) Television Questions & Answers
Hello, Here is website for help: Universal Remote Codes Remotecodelist com
Hannspree... | Answered on Jun 11, 2014
Hi
maube you have lost contact in your remote wiring! please check the remote area and power oscillation area.
Thanks!
Hannspree... | Answered on May 10, 2014
First I am glad helped with the other issue.
This issue needs to be defined: do you hear the buzz when sound is at zero? I not the issue is in audio circuit or signal to set----If you hear the buzz with sound off it is likely something in the set vibrating hard enough to make the noise.
What causes this is a part that is not bad but noisy--there are ways to deal with this depending on set.
My real concern is if set is opened etc it will void your warranty!
If 5 days old most major stores will take it back or issue credit so you can replace the set----makers will often play a shell game--tell you it MUST go in for repair.
Most major stores have an unwritten rule here: set can be returned within first 30 days and exchange/replaced for ANY reason.
Seen ones returned because owner did not like the color of the cabinet etc.
If I know what type of set it is (has a picture tube, LCD etc and you have no warranty I can tell you what to look for and a possible way to fix it---Don't void the warranty if you have one by just opening it.
Saw a (will not call him stupid) person with a 1,000 set here yesterday which clearly had a problem and was 3 days old open the set and in doing so removed the labels there to indicate if someone has tampered with the set---now he has no warranty and a non working set.
Hannspree... | Answered on Nov 15, 2012
Please check here for information regarding Hannspree Universal Remote information. Basically, only the DirectTV Big Button remote has the Hannspree codes available.
Hannspree... | Answered on Sep 25, 2012
Hi.
No sound on some channels only is quite unusual. If the TV is connected to an external receiver, then the problem is the external receiver box.
If you get the problem with TV connected directly to the aerial, then it is likely a faulty internal TV tuner.
In that case contact Hannspree at the number listed on the owners manual for repair.
See also: Welcome to Hannspree
Hannspree... | Answered on Jul 01, 2012
there's no faulty parts on your unit but sure that you have a dry joints on the sound amplifier section.
Look for a qualified technician to re-solder for a dry joint on the said section and it will fix the problem.
If you have knowledge in soldering then open the back panel of your tv.
Then observe first because you have to pull-out some connector from the main board.
Remember that anything you pull-out will be back to their position as you finished resoldering.
Try to trace the connectors of your speaker to the main board.
It is connected to ic which have a heat sink.That's the sound amplifier ic.
Find the cold solder around there then resolder it.
You can try the tv, if you hit the cold solder then intermittent sound will be cured.
Remember that before you try turning on the unit be sure that you returned the connectors to its original position. gud luck buddy...
Thanks for using fixya...
Did you find a solution? I have the same issue.
Hannspree... | Answered on Jun 03, 2012
On a 32 inch it may not be worth fixing--not going to be a reset etc--base decision on fact that possible repair should not exceed used value of set--which in my view it likely will.
Hannspree... | Answered on May 27, 2012
The language will be indicated in the menu--if another language other than English--use the free Google "Babel Fish" to translate words to english and then in the menu make the correction back----menu button on remote or set should take you there.
Hannspree... | Answered on Apr 30, 2012
Hi
There website isn't specific where there products are made but I would guess China. They have divisions all over the world.
Hannspree... | Answered on Oct 24, 2011
Hannspree (K206-10U1-005) Television Logo
89 questions posted
Top Hannspree Televison & Video Experts
paul
paul
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hannspree Televison & Video
Most Popular Question
all 2 question lol first language tv
  • Televison & Video
