20 Most Recent Polaroid FDM-0715 Television Questions & Answers
No volume on the cable tv setting?
Does the set have a earphone jack? if dirty or damaged it will cut the TV sound out---about the only other possible reason is a audio problem in the TV itself---if possible put ear up to speaker to see if any sound or buzz is heard.
12/4/2012 2:53:15 PM • Polaroid... • Answered on Dec 04, 2012
Remote Control Program Code
Try the samsung code.
6/8/2010 3:08:56 AM • Polaroid... • Answered on Jun 08, 2010
Polaroid TV working with constant red flashing light
If your Polaroid Roku TV is working fine but the red light is continuously flashing, it could indicate an issue that may need attention. Here are some steps you can try to troubleshoot the problem:
  1. Power Cycle:
    • Turn off the TV and unplug it from the power source.
    • Wait for at least 5 minutes.
    • Plug the TV back in and turn it on.
  2. Check Remote Control:
    • Ensure that there are no stuck buttons on the remote control. Press each button to make sure they are not stuck in the pressed position.
  3. Update Firmware:
    • Check if there is a firmware update available for your TV. You can usually find this information in the TV's settings menu.
  4. Reset to Factory Settings:
    • Perform a factory reset on your TV. This will erase your settings, so be sure to back up any important information first.
  5. Check for Physical Obstructions:
    • Make sure there are no physical obstructions around the TV, particularly around the infrared sensor on the TV and the remote control.
  6. Contact Customer Support:
    • If the issue persists and your TV is still under warranty, consider contacting Polaroid customer support for assistance. They may be able to provide additional troubleshooting steps or offer a solution.
  7. Professional Repair:
    • If the TV is no longer under warranty and the issue persists, it might be advisable to consult a professional technician or a TV repair service to diagnose and fix the problem.
Always refer to your TV's user manual for specific instructions related to your model. If none of the above steps resolve the issue, it's recommended to seek assistance from the manufacturer or a qualified technician for further diagnosis and repair.
12/27/2023 10:15:57 PM • Polaroid... • Answered on Dec 27, 2023
Have a tdac-01933 tv/dvd Polaroid no remote black screen with manual power on options please
See Hints and Tips section of manual on page 36. Your problem is discussed there. Help And Tips - Polaroid 19" HD-READY User Manual [Page 39] ' ManualsLib
12/22/2023 12:36:11 PM • Polaroid... • Answered on Dec 22, 2023
How to turn on audio description on a polaroid tv?
MY polaroid smart tv has narration voice on it and I don't know how to turn it off
11/19/2023 6:00:40 PM • Polaroid... • Answered on Nov 19, 2023
Polaroid P50D300FP(A) Smart Television. How to fix TV No image (flashlight test).
From a previous post and an answer from our Television Expert Larry, normally not worth repairing Polaroid televisions are made in China and are not made with quality components. Wow, they are only $239 new, what quality can you expect? His advice was to replace with mainstream brands like Sony, LG or Samsung.
Polaroid P50D300FP 50 Inch SMART Full HD LED TV ...
Electrical Deals https://www.electrical-deals.co.uk > brand-new-polaroi... Full HD resolution for clarity; SMART features for extra content; Freeview Play for a variety of channels; USB Recording to never miss a moment. £239.99 You can get boards for $10 https://www.google.com/search?q=P50D300FP(A)
11/12/2023 12:26:45 AM • Polaroid... • Answered on Nov 12, 2023
2answers
Polaroid TV 50". I have a fault across bottom of screen, a transparent band about 2 inches high. Can it be fixed and is it worth it?
No Model number, '50 inch' is just a size.Can it be fixed? Yes, they can all be fixed.Is it worth it? Unlikely. Polaroid are a camera maker and don't have a good name in televisions.Hopefully our television @Larry will be along to confirm.https://www.google.com/search?q=Polaroid+TV+50%22+fault+across+bottom+of+screen%2C+transparent+band+about+2+inches+high..
10/29/2023 4:32:41 PM • Polaroid... • Answered on Oct 29, 2023
Can you tell me the code for a Polaroid TV for SANSAI URC-L969 universal remote please.
First is a link to a codes page. Next is a description of programming the device. The code page strikes me a little confusing about the method so that is why I provide the description of programming. Polaroid TV Universal Remote Codes & Program Instructions - Universal Remote Codes
  1. Turn on your Polaroid TV.
  2. Press and hold the SET button on your SANSAI URC-L969 universal remote until the LED light turns on.
  3. Enter the 3-digit code for your device using the number buttons on your remote. If you don't know the code, try searching for it online or contact the manufacturer of your device.
  4. Release the SET button once you've entered the code.
  5. Test if your remote is working by pressing some buttons like volume up/down or channel up/down.
10/28/2023 7:27:19 AM • Polaroid... • Answered on Oct 28, 2023
Polaroid TV blue and pink lines only on playback
delete the Apps reset the television reload the Apps
9/13/2023 6:41:28 PM • Polaroid... • Answered on Sep 13, 2023
4OGSR300 Polaroid tv. volume down on tv when pressed powers it off instead. My question is there a way to get volume down until my remote comes in. Thanks in advance
Search for your TV model's official app or a universal remote app that's compatible with your TV.
8/21/2023 5:11:59 PM • Polaroid... • Answered on Aug 21, 2023
How to press 'OK' on Polaroid television without the remote?
You can't unless it has a 4 way directional pad with enter in the centre. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
7/4/2023 7:48:17 PM • Polaroid... • Answered on Jul 04, 2023
2answers
On a polaroid HDTV,the volume says 100% yet we can barely hear it.Is there a way to turn it up any more?
There would not be a way to " turn it up more" chances are something is bad in the audio output circuitry, this is part of the main board, or your set may be an all in one set where there is only one board in the TV. A new board should fix the set.
4/9/2023 1:32:16 PM • Polaroid... • Answered on Apr 09, 2023
2answers
How do I switch my Polaroid P40LED13 TV on to AV mode. No option in sources
If you are using the standard SNES cables with the round red, white and yellow 'Jack' plug connectors they are referred to as "Component" connections. On your remote there should be a button marked "COMP". It will probably be near the top of the remote near the Power button. This should switch the TV to the channel you need.
3/27/2023 9:22:04 PM • Polaroid... • Answered on Mar 27, 2023
Polaroid pdx-0758 dvd player displays "open" even though thelid is properly closed, and it will not play
If your Polaroid PDX-0758 DVD player is displaying "open" even though the lid is properly closed, there are a few potential solutions you can try:
  1. Check for obstructions: Make sure that there are no objects blocking the DVD tray or preventing it from closing all the way. Even small objects like dust or debris can interfere with the DVD player's operation.
  2. Reset the DVD player: Try unplugging the DVD player from the power outlet and waiting a few minutes before plugging it back in. This can sometimes reset the player and clear any errors that might be causing the "open" message to appear.
  3. Clean the DVD player: Use a soft, dry cloth to clean the DVD player and remove any dust or debris that might be interfering with the player's operation.
  4. Try a different disc: Sometimes, a specific disc might cause the "open" message to appear. Try playing a different DVD to see if the player operates normally.
If none of these solutions work, there could be a more serious issue with the DVD player's hardware or firmware. In this case, you may need to contact Polaroid customer support or a certified repair technician for further assistance.
3/15/2023 8:15:20 PM • Polaroid... • Answered on Mar 15, 2023
My Polaroid Bluetooth speaker model PBT 3027 makes a ticking noise. How can I fix it please.
Does it do it everywhere, even in the middle of a field? If it does, contact Polaroid for a warranty replacement. If it only does it as home or in the car it is picking up interference. Not much you can do, as these are at the budget end of the scale.
2/1/2023 6:11:13 AM • Polaroid... • Answered on Feb 01, 2023
My polaroid TV model 3200 has vertical lines in the picture and color is a little bit off. Any solutions?
The issue you're describing with vertical lines in the picture and a color imbalance on your Polaroid TV (model 3200) could be caused by a few different issues. Some possible solutions include:
  1. Check the TV's cable connections: Make sure all cables (e.g. HDMI, AV, power) are securely connected to the TV and the source device (e.g. cable box, DVD player).
  2. Adjust the TV's settings: Check the TV's picture settings (brightness, contrast, color) and make sure they are set correctly. You can also try resetting the TV to its default settings.
  3. Check for interference: Ensure that there are no other electronic devices or appliances that may be causing interference with the TV's picture. Move the TV or other devices a few feet away from one another to see if the problem persists.
  4. Check for a faulty cable or source device: Try connecting the TV to a different source device or cable to see if the problem persists. This can help determine whether the issue is with the TV or with the cable or source device.
  5. Check for a hardware issue: If none of the above solutions work, the issue could be caused by a hardware problem with the TV. This could be a problem with the TV's screen or the circuit board. In this case, you may need to contact the manufacturer or a repair professional to have the TV serviced.
Please note that the age of the TV, if it's been dropped or mishandled, or if it's been exposed to extreme temperature changes or moisture, could also be a factor in the problem.
1/26/2023 1:24:33 PM • Polaroid... • Answered on Jan 26, 2023
How to remove the back off a Polaroid LED TV please?
Lay it face down on a couple of bath towels.
1/24/2023 10:13:08 PM • Polaroid... • Answered on Jan 24, 2023
Polaroid TV Volume stuck on 0 cannot change it
Try this. Take the batteries out of the remote, and use the Volume Up button on the television itself. Does that work? It is an odd fault that I have never heard of. Mind you, Polaroid are famous for cameras not televisions! https://www.fixya.com/support/r29790007-repairing_own_television ..
1/8/2023 8:47:38 PM • Polaroid... • Answered on Jan 08, 2023
Polaroid FDM-0715 Television Logo
5 questions posted
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Polaroid Televison & Video
Most Popular Question
no volume cable tv setting
  • Televison & Video
