20 Most Recent
Panasonic DMR-EZ37VS Questions & Answers
Cannot get VHS tape to eject. Keep getting F03 or
If all else fails...you may have to go inside and take a look. I had this happen to me and I found that a piece of plastic had somehow gotten into the moving parts. Remember to first UNPLUG the unit and don't touch any of the electronic parts/pieces. You're just looking at the VHS mechanical parts. Now that you're inside, if you can with any level of confidence...plug the unit in and try ejecting the tape. Watch for anything hanging up all the moving parts that eject the tape.
If you're at all not comfortable working around something like this with live power then DON'T DO IT! Take it to have it looked at.
But if you are OK doing this sort of thing, hopefully you'll see some piece of junk has fallen into the tape area and it jamming up the workings!
12/2/2015 10:31:50 PM •
Panasonic...
Answered
on Dec 02, 2015
The remote is not responding.
- Go ahead and press and hold the #2 button and the "Enter" button on your remote for 20 seconds and this will return control to your unit.
Regards,
Tony
5/27/2011 2:35:38 AM •
Panasonic...
Answered
on May 27, 2011
Vhs tape stuck in unit how do I remove
I have opened my vcr before and removed a tape. The repair shop charges $79 bucks and I could buy a new one for that so I figured what the heck. Unscrew and carefully remove the tape and screw back together. I have done this numerous times and it's worked fine.
9/29/2009 10:59:20 PM •
Panasonic...
Answered
on Sep 29, 2009
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
6/16/2009 3:56:04 AM •
Panasonic...
Answered
on Jun 16, 2009
Non Panasonic disk picture quality
The quality is the same , the machine is designed to put the same quality on any media brand. Sony is just as good if not better when it comes to quality issues.
5/12/2009 9:04:22 PM •
Panasonic...
Answered
on May 12, 2009
Remote
When I have the same issue with my dmr-ez37v I recover by unplugging the unit for about 15 seconds, then plugging it back in. It seems the unit get "hung" about once a month and requires a hard power reset.
Regards,
Bob Headrick
12/4/2008 5:22:32 AM •
Panasonic...
Answered
on Dec 04, 2008
Panasonic hds700tds playing audio no videos
- Check the Input Source: Make sure you have selected the correct input source on your TV for the device you are using. Use the remote control to cycle through the input options until you find the one connected to your video source.
- Check Video Connections: Ensure that all video cables (such as HDMI, component, or composite cables) are securely connected between your TV and the device you are trying to watch content from. A loose or faulty cable connection could result in a loss of video signal.
- Restart the TV and Video Source: Try restarting both your TV and the device you are trying to watch content from. Power off both devices, wait a few moments, and then power them back on. This can sometimes resolve temporary glitches or issues with the video signal.
- Check for Software Updates: Make sure your TV's firmware is up-to-date. Sometimes software updates can resolve compatibility issues or bugs that may be affecting video playback. Check the settings menu on your TV for an option to update the firmware, or visit the manufacturer's website for instructions on how to do so.
- Reset Video Settings: If you've made any changes to your TV's video settings, such as resolution or picture mode, try resetting them to their default values. This can sometimes resolve issues with video playback.
- Try a Different Device: If possible, try connecting a different device (such as a DVD player or gaming console) to your TV to see if the issue persists. This can help determine whether the problem lies with the TV itself or with the original device you were using.
- Contact Panasonic Support: If none of the above steps resolve the issue, it's possible there may be a hardware problem with your TV. In this case, you may need to contact Panasonic customer support for further assistance or to schedule a repair.
- Hope this helps
4/9/2024 11:43:10 PM •
Panasonic...
Answered
on Apr 09, 2024
I have a Panasonic 50-in flat screen TV a storm came by and knocked out my TV and my Yukon no breaker was off so did it come through the antenna please help
- Check the Power Cord: Ensure that the power cord is securely plugged into both the TV and the power outlet. Make sure there are no visible signs of damage to the power cord or the plug.
- Inspect the Power Outlet: Try plugging another electronic device (such as a lamp or a phone charger) into the same outlet to verify if it is functioning properly. If other devices work fine, then the issue is likely not with the power outlet.
- Check for Tripped Circuit Breakers: Check your circuit breaker or fuse box to see if a circuit breaker has been tripped or a fuse blown. If so, reset the circuit breaker or replace the fuse and try plugging in your TV again.
- Test with Different Power Source: If possible, try plugging your TV into a different power source altogether, such as a different room or building. This will help determine if the issue is specific to the power source you were previously using.
- Contact Panasonic Support: If none of the above steps resolve the issue and your TV still does not power on, it's likely that there is a hardware problem with the TV itself. In this case, you may need to contact Panasonic customer support for further assistance or to arrange for repairs. Be sure to provide them with details of the troubleshooting steps you've already taken.
Hope this helps
4/9/2024 7:56:16 PM •
Panasonic...
Answered
on Apr 09, 2024
