20 Most Recent Kyocera CS-2550 Black and White Copier Questions & Answers
How to clear memory on kyocera fs1135?
Unplug for 5 mins.
12/24/2019 3:35:41 AM • Kyocera CS-2550... • Answered on Dec 24, 2019
4answers
I have Kyocera km-2050 it
press 1087, 1087 until the machine shows U000 self status, press 163, press start and then scroll to execute and then press enter. the machine will iunitialize and come ready for copying
12/8/2018 6:53:37 AM • Kyocera CS-2550... • Answered on Dec 08, 2018
Print mode error
check that the paper size is correct on your machine then turn it off and on and the device your printing from. basically reset both. if that doesnt solve it check that the driver is correct reload driver and check connections
11/2/2015 4:26:23 AM • Kyocera CS-2550... • Answered on Nov 02, 2015
2answers
1 copy to front and back from computer
umm if I understand correctly you want one document printed same document on both sides select double side printing the where it ask for how many copies you want send to or how many of the documents you want in increments of two ex. 2=1 double side copy,4=2 double sided ,6=3double sided
11/2/2015 4:21:52 AM • Kyocera CS-2550... • Answered on Nov 02, 2015
3answers
Kyocera 2550 Scans but how do I OCR?
You can find documentation form Kyocera Printers here, though it barely mentions anything about their OCR feature:
http://usa.kyoceramita.com/americas/jsp/Kyocera/home.jsp
The OCR feature is only an image quality setting, producing a more black and white high contrast image rather than a grey scale image.
I'm using our Kyoceras to email the images to a server where "send mail" processes the image and runs OCRopus, an open source Google funded OCR project, to read information from the scan.
I'm finding there are many Virtual ReScan solutions, like Kyocera's OCR feature, VRS software produces OCR optimized images, though I haven't found an open source VRS project.
10/17/2015 4:46:27 AM • Kyocera CS-2550... • Answered on Oct 17, 2015
0answers
Scanner password
HI there try the following.
  • Open Internet Explorer
  • Type in the address bar the IP address of the scanner (If you do not know this print out a status page)
  • Once you have typed in the IP address you will then have the scanner configuration screen on the left you should have passwords section you will be able to change it from there.
Hope this helps you
Thanks J
2/26/2013 5:20:20 AM • Kyocera CS-2550... • Answered on Feb 26, 2013
2answers
Scanner - memory is full
A KM-2550 has 64 MB RAM built in. I believe less than 30 of it is for image storage. You may be able to lower your scan resolution.
Best solution is to add more memory. Look for a Kyocera compatible 100 pin dimm (don't buy from the manufacturer). It will read 16 MB to 256 MB sticks. You have to take out 6-8 screws holding on the part of the back the sticks out on the upper left. Make sure after installing you print a status page to make sure the memory was recognized.
8/7/2012 8:45:34 PM • Kyocera CS-2550... • Answered on Aug 07, 2012
Entire page is black when trying to make a copy.
does the exposure lamp lights when u make a copy. if yes thenthe charging wire might be broken .check and replace it. it can also be the high voltage supply board .
9/13/2011 2:44:47 AM • Kyocera CS-2550... • Answered on Sep 13, 2011
We have a KM 2550 copier and I am trying to get a
Hey is a link to the Kyocera website that will allow you to get all the manuals for this model for free.
http://usa.kyoceramita.com/americas/jsp/Kyocera/download_center.jsp?pid=13703&pcat=10564&rcid=10009&rscid=10028&x=21&y=5#bottom
Hope this helps.
7/14/2011 4:14:56 AM • Kyocera CS-2550... • Answered on Jul 14, 2011
The copier keeps printing the same document.
Try this... Remove all the connection to the PC (USB, network or parallel). Turn off the printer on the power plug for about 3-5 minutes. This will clear all the documents sent previously.
3/9/2011 1:11:03 PM • Kyocera CS-2550... • Answered on Mar 09, 2011
Print mode error
check the paper size from your page setup
2/16/2011 6:37:15 AM • Kyocera CS-2550... • Answered on Feb 16, 2011
We have had labels stick to the drum of our copier
can you place your labels on the multipurpose tray instead of using the cassette
9/27/2010 1:16:19 PM • Kyocera CS-2550... • Answered on Sep 27, 2010
Kyocera CS-2550 Black and White Copier Logo
57 questions posted
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kyocera Office Equipment & Supplies
Most Popular Question
kyocera km 2050
  • Office Equipment & Supplies
