20 Most Recent Cuisinart ICE-45 1.5 Quart Ice Cream Maker Questions & Answers
Problem with the Cuisinart ICE-45 1.5 Quart Ice
There IS a silicon ring that fits in a groove on the bottom of the freezing bowl. I lost the one on mine, which causes the leaking described. I replaced it with a silicon O-ring (1" inner diameter, 1 1/4" outer diameter, ring thickness 1/8") that I found on Amazon - did have to buy a set with lots of different sizes but now I have extras in case I lose it again. Works perfectly without leaking.
1/31/2022 4:21:07 AM • Cuisinart ICE-45... • Answered on Jan 31, 2022
2answers
I have an ice cream
Check that all gears are in good working order. The paddlewill not turn properly and the motor will not run if the gears are worn ordamaged gears. Inspect the paddle for damage and replace if necessary. You alsomay need to replace worn or damaged gears in the motor. Lubricate the motor,drive shaft and motor bearings. Hope this will help you. Good Luck.
9/4/2011 5:11:54 AM • Cuisinart ICE-45... • Answered on Sep 04, 2011
Simple Vanilla Ice Cream from recipe booklet is
Your freezer is not cold enough. I had a heck of a time with this machine the first few attempts, when I was in storing it in my main freezer (less cold than the one in my garage). Then i froze the bowl in my garage freezer - it is set to below 32 degrees Farenheit and is designed for long-term storage (gives anything I put in it major freezer burn). When the freezer is set to a low enough temperature, you will find that even 14 minutes is plenty of time to acheive the desired ice cream consistency in the ICE-45 (without having to pre-chill the ingredients).
Other things to check:
Make sure you are using heavy whipping cream and not half-and-half or other substitute.
Make sure that you wait until you are ready to pour the ingredients into the bowl BEFORE taking the bowl out of the freezer.
9/29/2009 7:20:46 AM • Cuisinart ICE-45... • Answered on Sep 29, 2009
I don't have a Manual Guide for my ICE-45 soft
Here is the official manual from Cuisinart's website:
http://www.cuisinart.com/share/pdf/manuals/ice-45.pdf
9/29/2009 6:01:15 AM • Cuisinart ICE-45... • Answered on Sep 29, 2009
We lost the manual & I just would like to
You should be able to download the manual from the manufacturers web site.
6/17/2009 2:34:45 PM • Cuisinart ICE-45... • Answered on Jun 17, 2009
No power to the unit
Make sure the bowl and mixing paddle are in correct place, and that lid is locked into place. Turn dial to on and try again. If this fails to resolve, replace it -has a 3 year warranty.
12/9/2008 7:55:54 AM • Cuisinart ICE-45... • Answered on Dec 09, 2008
Missing top
4/24/2008 9:52:08 PM • Cuisinart ICE-45... • Answered on Apr 24, 2008
The timer on my Cuisinart ice cream machine won't beep anymore at the end of the cycle
Your washing machine turned into an Ice Cream Maker! Try a Power Reset. Sometimes it is as easy as disconnecting from the mains supply for 5 minutes and plugging back in. Some models use a number of keys, press and hold. Google make model reset gives this
Frozen Yogurt-Sorbet & Ice Cream Maker - Cuisinart
https://www.cuisinart.ca > en_CA > ICE-30WNC_en PDF To reset the unit, turn the ON/OFF switch to the OFF position. Let the unit cool off. After a few minutes, you may turn the unit on again and continue making ...
It may be that the sound sender device is faulty, or even a main control board issue. No one else has encountered your issue. https://www.google.com/search?q=Cuisinart+ice+cream+doesn%27t+beep ..
7/17/2022 4:43:17 PM • Cuisinart Ice... • Answered on Jul 17, 2022
2answers
Motor making loud noise and Shaft not turning Is repair possible
The bearing or bush of the motor would be faulty. try to put some oil on the shaft. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
4/7/2022 2:12:13 AM • Cuisinart Ice... • Answered on Apr 07, 2022
Why does commercial ice cream remain "scoopable," while my Cuisinart ice cream is as hard as concrete?
Additives and air. Gums, emulsifiers and stabilizers are commonly added to commercial ice cream, and generally there is more air whipped into the commercial ice cream during freezing in the manufacturing process.
12/29/2019 10:52:00 AM • Cuisinart Ice... • Answered on Dec 29, 2019
I have cuisinart ice cream machine, and i live in UAE ( united arab emarties). We have 220 v and the machine motor is 120v so i plog it in and i think i broken somthing in the motor so how i can fix it or repalce it. Thank you
First you can not run this machine on 220 Volts, it probably burnt up the motor and every thing else on it. The only way you can use a 110 volt unit on 220 is to buy a step down trans former and install it which will take the 220 down to 110.
2/5/2018 4:55:38 PM • Cuisinart Ice... • Answered on Feb 05, 2018
Will not turn at all just makes humming noise
I had one do that and I opened the gear box and found that the last time we made ice cream & it started getting hard the motor caused the gear to pop a tooth off (plastic). so now you hear the motor running but no transmission. Take it apart and check or turn the ice cream tub connection socket 1/4 turn and see if that makes a difference.
11/18/2015 1:00:48 PM • Cuisinart Ice... • Answered on Nov 18, 2015
Cuisinart ICE-45 1.5 Quart Ice Cream Maker Logo
15 questions posted
Top Cuisinart Ice Cream Makers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Cuisinart Ice Cream Maker Expert? Answer questions, earn points and help others
View Most Popular
  • Cuisinart Ice Cream Makers
Most Popular Question
simple vanilla ice cream from recipe
  • Ice Cream Makers
