20 Most Recent Frigidaire PLD4375RFC Dishwasher Questions & Answers
Frigidaire dishwasher door won't close
with aa small thin screwdriver you can try to pry the "latch/catch "back to an open positon
8/17/2022 2:53:28 PM • Frigidaire... • Answered on Aug 17, 2022
4answers
My dishes come out gritty,
Could be food debris cooked into the element, or possibly scale build up in it. Either way, there are dishwasher cleaning chemicals available in shops. There will also be a filter in the wash tank that can be removed and cleaned. I would suggest getting a cleaning shot or two and running the machine on its hottest wash a few times to start with. If this doesn't sort it out then see about getting the wash tank descaled
11/3/2017 8:01:50 AM • Frigidaire... • Answered on Nov 03, 2017
How can I fix my Frigidaire PLD4375RFC Dishwasher that leaks from bottom door even after new door gaskets 154576501 and 154701001.
It sounds like you are fixing the wrong area. If water is coming down between the inner and outer door panel and following the wiring harness, the leak is inside the door. Either from the soap cup mounting or the rinse agent area which I think is the same unit on your model. There is a gasket behind that part. Also check the inner door if its plastic for any possible cracks.
4/23/2015 4:24:50 PM • Frigidaire... • Answered on Apr 23, 2015
0answers
Frigidaire PLD4375RFC3 panel blinks and make sounds
why machines gs502 report err 4?
2/19/2014 1:31:42 AM • Frigidaire... • Answered on Feb 19, 2014
Does not clean dishes
Hi Tim - I understand that your dishes are not coming out clean. There can be several things that you might want to try. First, make sure that your detergent is fresh. If not, try using a fresh detergent. Next thing I would try would be to make sure that everything is loaded correctly so nothing is blocking the spray arms inside, and preventing them from rotating. After that you can check to make sure that the water coming into the Dishwasher is hot enough. Try running the water into the sink until it becomes hot and then starting the dishwasher. If you're still having trouble after that, you might want to check and see if you have hard water. If you do, you'll want to make sure that you are filling the dispenser cup completely and if you have soft water you'll want to make sure that you use less detergent. The only other thing that I can think of that might cause the dishes to not be clean would be maybe the water pressure itself. If the pressure is good, you might need to reach out to a local service tech who can better pinpoint the problem for you. Best of luck!
12/19/2013 7:57:10 PM • Frigidaire... • Answered on Dec 19, 2013
0answers
6 mo. old frigidaire d/w displays the "ER clean S" flashing error
Probably a control panel failure. This unit does not ventfrom the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works it's way into the control panel eventually.
12/11/2013 1:21:32 AM • Frigidaire... • Answered on Dec 11, 2013
Incomplete cleaning
check out www.dishwasherfilter.com because there system filters your water before entering the dishwasher. I am sure it will solve your problem and its guaranteed or your money back.
6/26/2013 1:14:15 PM • Frigidaire... • Answered on Jun 26, 2013
2answers
Leaking door
They had a big problem with this model leaking at the corners of the doors. I would replace the baffle (part# 154576501) and install a splash shield kit (part# 154701001, comes with instructions)
11/25/2012 5:45:17 AM • Frigidaire... • Answered on Nov 25, 2012
Frigidaire PLD4375RFC Dishwasher Logo
108 questions posted
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Dishwashers
Most Popular Question
  • Dishwashers
