20 Most Recent
LG LMV1630 Convection/Microwave Oven Questions & Answers
Touch pad inoperaive
Unfortunately, if you are having problems with a touch pad you will probably have to replace either the touch pad itself, if you can get it or the whole control board and touch pad as a unit which normally ends up running as much as a new microwave. I would check your warranty and see if it still is covered and proceed that direction.
What is the temperature attained
The mass of the material you are heating affects the temperature achieved. ie. 2pints of liquid will reach a lower temperature than 1pint in 100 seconds.
Glass in door is loose
you may be able to dissassemble door and reattach glass with a hot glue gun. the plastic tabs are more than likely broken.
TURN TABLE STOPPED TURNING
On some microwaves there are several drive rollers under the turntable. It's possible that these are slipping due to dirt build up. Try removing the turntable and clean the rollers.
11/26/2010 10:40:13 PM •
LG LMV1630...
Answered
on Nov 26, 2010
