20 Most Recent
La Pavoni Pub V1 Espresso Machine Questions & Answers
HELP, the screw that holds
A hard one to help because I would need to see it and the area involved which would determine a method.
Wire cutters of suitable size are good for pozi-philips types gripping between side and centre "hole".
A fine metal saw to cut a slot (jewelers metal saw) which are inexpensive if small screws are involved I find are good.
You could file two flats on the head on opposite sides or use a Dremel type tool with diamond disc to do it, so to get a better grip.
If its a screw in a brass insert into plastic then a small amount of heat (soldering iron) to soften plastic (via the screw head) its inserted in then prise out in a vertical manner, then re-glue insert back in after sorting things out.
If we are talking about a screw into a metal threaded item then praying its not stainless steel drill that screw out with a cobalt type (very hard compared to HSS steel) drill bit starting under thread size working up, at some point the head may come off, depending on screw size a square file tip can be inserted in the hole to act as a gripper but beware small files are brittle so would break if over forced. Larger types of this method would involve a shaped Allen key to wedge in this hole or a nail like a masonry type which is hard duly shaped with four flat sides to grip.
I could go on but I think you got the principle ideas, only you can evaluate which is best, my advice is to think out methods rather than jump straight in that suit this event.
Hope this helps......
I need 120 v
You can check with Espressopartsnw.com or crossroads espresso(coffeestuff.com) they are the pavoni distributors.
La pavoni slow water flow
Try running some white vinegar through it as if you was making coffee (but don't use any coffee) and when done either repeat processes or run a clean pot of water to clean out the vinegar and see if the water is coming out faster. You might need to repeat process a few times. The vinegar breaks down any hard water residue.
What causes my la pavoni europicola to make a whistling when it;s turned on?
hi
it is normal when water heating up and pressure begin to be built in the boiler until the vacuum braker at the safety valve close
but if it continue to whistle when the green light goes off
after few minutes it means you have too much pressure in the boiler and it is realesed through the safety valve
in that case you have to replace your pressurestat or you have scale at the bottom of boiler in the entrance of the pipe leading to the pressurestat
regards
Guy
