20 Most Recent
EW3100 Radar Detector Questions & Answers
Early Warning EW-3400 Radar Detector Digital Compass Calibration??
I looked at another simuilar Detector and read on Digital Compass Calibration and through the process of elimination found that if I Press CITY for 3 sec.'s COMPASS CALIBRATION showed on the display. Then it says TURN YOUR VEHICLE SLOWLY 2 TIMES to CALIBRATE. Then press the CITY button to complete the calibration. Done. It worked my Early Warning EW-3400 Radar Detector's Compass is now Calibrated.
Thanks for asking.
No audio output
Well besides the obvious of voice off/on the speaker could be blown. I have one of these units but have not cracked it open. My speaker has blown twice on my passport 9500i and I just replaced it myself. It's out of warrantee and Escort wouldn't send me a speaker, so I got one from radio shack and that worked for a while, then blew. I used a laptop internal speaker now and that works great ! BTW if the speaker on this unit is soldered to the board good luck, like I said I haven't cracked my ew3100 open yet.
Can the p olice detect a ew 3100 is on in your car
I would probably say vg2 no, spectre yes. This unit is decent, in fact i really like the 1-9 and how accurate it is with the proximity. I have a $450 detector that is horrible at judging the distance to the source of the radar. Anyway it has been my observation that this unit irritates other detectors more so than others, which is a sign of a leaky detector. Also if it detects pop, i noticed that the pop is always on, and the falses on pop are very minimal compared to other units..
Early Warning EW 3005 Safety Radar Laser Detector manual
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals and it's verrrrry cheap and mine
I got free in offers
3rd time I also had an issue with the file so the girl replaced it in 30 mins
there is one more but i don't remember its name it was 2 years back bitman something link this
Try it out brother
What is the supply voltage
Supply voltage is the positive voltage supplied by the vehicle's battery + or positive post typically 12 volts. the other side is negative, if you are hard wiring an accessory in, make sure to go to your fuse panel, use a multimeter to verify it turns off with the key then get a fuse tap at a local parts store to connect.
How to make radar electronically
This is not something to try unless you have a ton of engineering expertise, and hundreds of thousands of dollars for test equipment. High frequency RF signals are some of the most challenging electrical engineering problems that exist.
Icons and what do they mean
Speed cameras usually are located either at intersections or along roadways. Many red light camera models used at traffic intersections also function as speed cameras. These speed cameras will mail you a speeding citation if the camera thinks that you are speeding. Your GPS navigator is warning you about nearby speed cameras. It displays red as you approach the speed camera location where you could get an automatic electronic ticket if you are speeding.
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
What is hashtag
hash·tag
noun
(on social media sites such as Twitter) a word or phrase preceded by a hash or pound signand used to identify messages on a specific topic."spammers often broadcast tweets with popular hashtags even if the tweet has nothing to do with them"
the hash or pound sign (#)."Hunt mistook an @ for a hashtag while tweeting derogatory thoughts about him"
