20 Most Recent
Sennheiser RS 140 Consumer Headphones Questions & Answers
My headphones can't hold a
The green light signals that the unit is operational and working normally. The orange light signals that the sound is too loud and it will have to be compressed, again, normal behaviour.
The charge of the batteries is smaller than what it used to be in 3 cases:
1 - the capacity of the new batteries is smaller than that of the old ones. Compare the old and the new and this is the case then the only thing you can do is to buy another larger ones.
2 - the batteries aren't fully charged. You must keep them plugged in the charger until the red light starts to blink slowly. - about 16 hours for the first time then the same amount they were used.
3 - it's not just the batteries that age, the charges also does it. When that happens it can no longer deliver the full charge to the batteries no matter how long you keep them plugged so they just drain a lot faster - you must buy a new one.
I need a manual for RS 140 head phones
You can download the complete instruction manual in PDF format by clicking this
link.
For more details, features and specifications, click
here.
- You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using
FixYa.
Hissing and poor sound quality
Well it could be interference from the TV, computer, or other 900Mhz device (some wireless routers run on this frequency).
I'm currently dealing with the same issue myself, if I find a solution I'll post back.
Sennheiser rs-126 connection
Yes, you may. RCA connections are universal, just don't connect an input lead to an output jack: you might damage the jack.
Headphones support
The problem is: All woks godd for the sound but the support of earsphone is broken in the middle and the company ask the price of a new one to repair.
Sennheiser RS 175 TV headset has green lit power light blinks on and off. And headset doesnt have any volume. Help!
If your Sennheiser RS 175 TV headset has a green lit power light that blinks on and off and doesn't have any volume, here are some troubleshooting steps you can try:
- Check the batteries: Ensure that the batteries are charged and inserted correctly into the headset. You may also want to try replacing the batteries with fresh ones.
- Check the audio source: Make sure that the audio source is turned on and the volume is turned up. You may also want to try connecting the headset to a different audio source to see if the problem is with the source.
- Check the audio cable: If you are using an audio cable to connect the headset to the audio source, make sure that it is plugged in securely at both ends.
- Reset the headset: Try resetting the headset by turning it off, unplugging the transmitter from the power source, waiting for a few minutes, and then plugging the transmitter back in and turning the headset on again.
- Check for interference: Make sure that the transmitter and headset are not too far apart or obstructed by walls or other objects. Also, ensure that there are no other devices nearby that may be causing interference.
If none of these troubleshooting steps work, you may need to contact Sennheiser customer support or take the headset in for repair.
HOW DO I CONNECT MY SENNHEISER RS 120 HEADPHONES TO MY LG UHD TV MODEL 55UK63
Hello Mike, your LG TV, does not have a headphone output, it only has optical fiber audio output
the options that I suggest are,
1) Connect the optical fiber output of the LG, to an AV receiver, that has said input and place the headphones in this equipment,
2) Buy an optical fiber to audio converter by RCA L and R and this is connected to a headphone amplifier
I send you links to the products that are sold in my country
I hope you solve your concern
Greetings Franco Dosil
This is the headphone amplifier
This is the optical fiber to audio converter by RCA L and R
Hola Mike, tu TV LG, no cuenta con salida de auriculares, solamente tiene salida de audio por fibra ?ptica
las opciones que te sugiero son,
1) Conectar la salida de fibra ?ptica del LG, a un receptor AV, que cuente con dicha entrada y colocar los auriculares en este equipo,
2) Comprar un conversor de fibra ?ptica a audio por RCA L y R y este conectarlo a un amplificador para auriculares
Te env?o links de los productos que se venden en mi pa?s
Espero logres resolver tu inquietud
Saludos Franco Dosil
este es el amplificador de auriculares
Este es el conversor de fibra ?ptica a audio por RCA L y R
Este es el amplificador de auriculares
https://articulo.mercadolibre.com.ar/MLA-784156450-behringer-ma400-ultra-compact-monitor-auricular-amplificador-_JM
This is the fiber optic to analog audio converter
https://articulo.mercadolibre.com.ar/MLA-707192478-convertidor-audio-digital-toslink-optico-coaxial-a-rca-nuevo-_JM
SENNHEISER EW100 G2 wireless microphone RECEIVER with lcd flashing all the time. Not functional.
Hi Edgar, it is important that the receiver works, because there is a dialogue between the transmitter and the receiver to confirm that they are on the same frequency, that is why the transmitter is blinking, you should repair the receiver and look for the frequency or channel that the transmitter is found and it will stop flashing
Hola Edgar, es importante que el receptor funcione, porque hay un dialogo entre el transmisor y el receptor para confirmar que est?n en la misma frecuencia, por eso es que el transmisor esta titilando, deber?as reparar el receptor y as? buscar la frecuencia o canal que se encuentra el transmisor y este dejara de titilar
