20 Most Recent
Marantz SR7001 Questions & Answers
Standby light is flashing on
hi,
First of all remove all the speaker connections from the amplifier. After that power the amplifier and check the Standby blinking (protect) show or not . if not, then any of the speaker is damaged also check the wire for any short circuit . If then also its goes to protection then it have some hardware truouble inside.
Amplifiers gose protect mode , when there is a hardware fault in side it. Its a warning that some thing is wrong.
Normally amplifiers show this when any of the output amplifier have some problem. there 6 amplifiers in this receiver . May occur when the output diver transistors of any of the amplifier become shorted. if the output transistor get shorted this will lead to flow of current through the speakers. To prevent this there is a protection circuit for each channels. One combined output of this protection circuit is connected to the system control. when the any of the output amplifier fails, the protection circuit detects it and switch of the speaker and sent data to the system control. when the system control get this data it will give a warning to the customer through display that PROTECT.
You have to check the amplifier.
For that you need digital multimeter,soledring iron screwdrivers etc
Open the amplifier , then power it on. Connect the negative terminal of the multimeter any where in the chase( metal body of the amplifer). Then connect the positive terminal to all the output transistors emitter pin one by one . The voltage should be bellow 0.5V. If any of the emitter of the transistor shows voltage more than +/- 0.5V., then that amplifier stage is faulty. Remove the transistors and check it. if it is shot then replace with a new one.
After replacing the transistors do not power up the amplifier directly from the main. You have to put a bulb of 60 watts in serial.
You can do this easily remove the mains fuse. Put the bulb in a holder. Now you have two wire from the holder. connect one of it to the one end of the fuse holder and the other wire to the other end of the fuse holder. Why using a bulb is, if there is any further problem in the amplifier stage on which the transistors replaced, there is a possibility of the new transistor get damage. if we use a bulb in serial with its mains supply ,when any overload in the amplifier occur the bulb will drop the current, by lighting itself.
After connecting the bulb in serious power on the amplifier. watch the bulb. It should light for one or two second and go dim ,then remove the power , remove the bulb insert fuse and connect the power and check.
(If the bulb shows bright light then there is some component also faulty in the same amplifier. after removing the power you have to check again the amplifier stage of which the transistor is replaced, for any other faulty components
OK
The red power light is
Its usually not a fault that you will see unless somethings burnt up. This is solid state electronics and you don't see this stuff go bad. But in the meantime try disconnecting the speakers and see if it still goes into shutdown and at the same time have a dc multimeter attached to the speaker outputs. If the unit comes on and you don't see any DC at all or very very little B+ on both speaker terminal sets then you may have a defective speaker. If you do see dc then that's why the protections coming on so you don't blow out your speakers. If you don't have any equipment or don't have any electronics experience I would then take the unit to a repair person for an estimate.
Good Luck in solving the problem.....
Marantz CD5004 tray keeps opening problem
CD/DVD players use a protocol;
Open tray. Insert disk. Tray switch tells mechacon that the tray is shut. Attempt to focus on disk.
If focus is acheived, then it will spin up and try to read the disk otherwise it will ask for a readable disk.
If the tray keeps opening, I would suspect the tray detect switch is malfunctioning, maybe the drive belt has stretched.
HI, would you know what error code CY920 on my Marantz NR1607 means ?
The Marantz NR1607 is an AV Receiver, and the CY920 error code is not a recognized error code for this product. It's possible that this is a custom or specific error code for your device, and I would recommend contacting Marantz support or the manufacturer for more information. They may be able to provide you with a solution or more information on what the error code specifically means and how to resolve it.
