20 Most Recent
Yamaha RX-N600 Receiver Questions & Answers
I plug my ethernet cable to my router/modem. But
Somewhere in the setup or settings for the network on your receiver make sure DHCP is turned on. DHCP (Dynamic Host Control Protocol) allows it to get a IP address and subnet from the router so it functions on the network. Likewise DHCP must be enabled on the router as well otherwise the downstream device (your receiver) won't be able to get an IP address.
IPod dock doesn't work
see the recepto Ipod is connected. Test the power cord, +test the receptacle wall.However clean the contacts for dity, oxide, with contacts cleaner( buy it fron any electronic store).God bless you
No sound with TV
my suggestion is to reset it to factory preset more than likely the pors that set you pu changed nothing for the origanal settings. heres how to set the reset:
1 press the masteron off on the front panelto the off position
2 press and hold the straight(effect) button then the master on off to turn on the set.
3 use the program selector to select factory presets
4 use the srtaight(effects) button to select reset then shut it off with thw master on off to lock in the setting turn it back on and you should be back to normal
My yamaha 600 tuner
you need to assign the input each of the inputs have a number assigned on the back of the unit. in the menu of the receiver assign the the number that the tv is in to TV or DTV or what ever you may have had it assigned to . the manual will tell you how to assign the inputs.
