20 Most Recent
Jwin iLuv i1055BLK Portable DVD Player Questions & Answers
Tv wont reset
Replace its main system control memory IC, and make an initialize.
If you wish to get more details, surf the
following link. There are over two thousand and four hundred posts. All are
related to television and other domestic electronic equipment service help. You
can get a solution there. Type in the brand name to your device to its search
box, can be located at the top right of the display window. It will make search
easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
Supergirl 13 color tv/dvd combo plays CDs but not DVDs...
If cleaning did not fix it the optical pickup for that unit is damaged in some way---if the set has audio/video INPUT jacks on it just buy a DVD player and hook it to the set.If no jacks you are finished--DVD portion of the unit if available costs more than the entire set.
I put in a dvd
You may want to try cleaning the drive using a drive cleaning disc, otherwise it's probably time to get a new one.
-=/ MLFnet /=-
I owned a Jwin portable
Most online stores don't have the power cord for your Jwin portable dvd player -JD-VD753/743. The below link is the best I can get amongst online stores.
http://www.bizrate.com/miscellaneous/jwin-portable-dvd-player/
Also, we don't stay in the same vicinity, so I wouldn't know precisely where you can get the power cord. But I believe there should be an electronic accessories store in your area. Try there and you should find a power cord for your Jwin portable dvd player.
If you don't find the exact adapter, you should at least find a closely related power cord with the same voltage or a universal power cord.
Good luck.
Only one channel going to b/w
Not the tv,it the brocasting incoming signal cable have a slice matalic contacting to that procise prequencies problems for that channel.Take another tv used it,with that incoming signal for that channel for a few days.See,if have a same problems have happen to another tv?Yes,than call the Cables,Dishes or Telicoms compannies,change that section of the incoming of broscasting signal cable line.Not,than take a piece of sand paper about 1000 grits,rub the input metal pin a few times,to have it better contact.
