20 Most Recent Magnum S9 Base CB Radio Questions & Answers
Talkback disabile
Remove the POWER or GROUND from the RX blocking diode next to the Audio Transformer.
4/3/2017 4:07:56 PM • Magnum S9 Base... • Answered on Apr 03, 2017
Am fm power to high keyup 60 watts ssb works fine mosfet 2030
If SSB works. then the AM - Regulator Transistor is bad.
4/3/2017 4:05:46 PM • Magnum S9 Base... • Answered on Apr 03, 2017
2answers
Where can I take my radio for repair in Wisconsin
I did a google search and the only CB shop I found was this one. Unfortunately there are not a lot of CB shops around any more. You may have to send it out to one for repair. Most do business over the internet now, and rely on shipping the radios. there are a bunch out there.
You can google any of these, or just CB repair.
Bells cb
Sparkys cb shack
radio active radios
There are a lot on the net that will do repairs via shipping.
11/16/2016 6:55:47 AM • Magnum S9 Base... • Answered on Nov 16, 2016
What does Ant stand for on Magnum s9
antenna
8/3/2016 12:37:35 PM • Magnum S9 Base... • Answered on Aug 03, 2016
2answers
Looking for a radio repair shop to work on a galexy radio in central wisconsin
when you say on frequency are you using the radio frequency counter or an external one ? If you mess round with the wrong adjustment you will never get it back on frequency . If you go to a truck stop , for the most , they all have a cb shop . There are two truck stops in black river falls and I'm positive one of them has a shop.
3/5/2015 11:18:58 PM • Magnum S9 Base... • Answered on Mar 05, 2015
I have a rm kl 203p amp would it be okay to hook it up with a magnum s9 50watt radio
be cairfull not to put too much power in the amp,
11/7/2013 2:01:18 PM • Magnum S9 Base... • Answered on Nov 07, 2013
manual
Where can i get a user manual for a magnum s 9
Hi and welcome to FixYa,
For the operating manual of a Magnum S-9, have you tried here?
Good luck and thank you for asking FixYa.
1/12/2013 3:00:44 PM • Magnum S9 Base... • Answered on Jan 12, 2013
2answers
Non capisco come leggere rf se 1 wat o 45
Parlate inglese? Sto utilizzando un traduttore in linea. Sono spiacente se è una traduzione difettosa. Potete inviarli con la posta elettronica a [email protected] se volete. La lettura del watt è su un tester di watt. è collegata fra l'antenna e la radio. la rf è potere di radiofrequenza.
11/1/2012 12:17:39 AM • Magnum S9 Base... • Answered on Nov 01, 2012
0answers
NO variable power on FM,or SSB, but variable works ok on AM
Look for open resistors near by, if the 2SC1969 shorted it has taken out one or two parts, also check for open foils on the printed circuit, beyond this a circuit diagram is needed.
3/26/2012 9:46:15 AM • Magnum S9 Base... • Answered on Mar 26, 2012
My magnum S9 wanders off freqency an the incoming
magnum s9 they seem to drift a bit on till they warm up my s9 dose the same on till it heats up then it comes ok
12/1/2011 12:16:28 AM • Magnum S9 Base... • Answered on Dec 01, 2011
Where can i obtain a wiring schmatic for an s9?
You can find all you need for this radio at www.cbtricks.com
Please don't forget to rate this solution.
7/22/2011 4:09:52 PM • Magnum S9 Base... • Answered on Jul 22, 2011
2answers
Anyone know why i have
sounds screwed...may be a short...change mics then try it....or take to repair shop.
7/19/2011 4:22:54 AM • Magnum S9 Base... • Answered on Jul 19, 2011
Hi mys9 with 1969
In answer to your question, no, it is no a problem with the final. I would try turning the ALC control (VR12) until you have 45 Watts out. (Ref Magnum S9 alignment procedure on CBtricks.com.
....Don at NTCB, Inc.
6/29/2011 3:25:44 PM • Magnum S9 Base... • Answered on Jun 29, 2011
0answers
No auddo cume tr and
You have a SWR problem..Check your cable and antenna..
4/17/2011 12:17:21 PM • Magnum S9 Base... • Answered on Apr 17, 2011
I got a used magnum S9 and i keep getting reports
find the mods on the radio to find out the limiter number example tr32 or dr 112these are not actual mods for your radio it will be listed on the green part of the board in white most likley it will be removed so you would have to get a new resistor and soldier it back in adjust your mic gain down and keep your moulth away from the mic when speaking if you havent done that already .You could take it to a tech.
4/7/2011 3:03:08 AM • Magnum S9 Base... • Answered on Apr 07, 2011
No power
Magnum s9 rf transistor replacement Hi i hope this link helps you out let me know how you get on with it cheers
3/16/2011 10:16:55 PM • Magnum S9 Base... • Answered on Mar 16, 2011
Magnum S9 Base CB Radio Logo
45 questions posted
Top Magnum Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Magnum Radio Communications
Most Popular Question
radio repair in wisconsin
  • Radio Communications
