20 Most Recent
Pioneer AVIC-N3 Car DVD Player Questions & Answers
When i turn on my
Sounds like it's worn out, best take into the shop for repair, should only cost $20 with parts.
Unit turns on. screan flips
I think there are problem with the screen flat cables might be foulty swap with another just to know if they are good .
good luck
How do i play a dvd in pioneer avic-n3 while in
ready. ground the e brake. green wire. also because you have a pioneer(i do to) you will need to have a switch where the driver can reach cause every time you turn off your car (acc) then start again this switch needs to be ungrounded then re grounded let e know how it goes.
Kieran
No audio on ipod
what gen is ure i pod as new gen i pods need a different connection as the plug is different. if its a gen2 or up it will need cord
No power on my avicn3
1. Check the obvious - fuses.
2. Is this a new problem, or a new installation that has never worked?
3. What were you doing when it lost power (if anything)
A more insightful question and background will give me a better chance of solving your problem.
Thanks!
nc
My avicn3 wont oower on but the red light flashes
Hello whiteboi147.
The red light flashes to indicate the power at 12 volt constant (yellow).
To turn the device on, it requires/needs a trigger from a switch of about 12 volt source (that is the red wire). Now, make sure it is hook up properly, if it is; check the power with any test light when the key is in accessory position/on.
Hope this helps.
How do i fix a
there are no internal wires in this unit. only circuitry. what seem to be the issue you are having and why do you think it is a wiring issue?
