20 Most Recent
Motorola Mobility HS815 Wireless Headset Questions & Answers
HOW I KNOW ABOUT MY
Hi, motorola headset pairing pin codes are set default at '0000'
If this helps please rate me
9/18/2010 6:30:15 PM •
Motorola...
Answered
on Sep 18, 2010
How do i pair this bluetooth ith my phone?
go to the menu on your phone select manage connections
turn on bluetooth then you'll see search listen, etc.position on search don't press yet
get your ear piece ready:
press the on button and hold it until you see a solid blue light (not blinking but solid) if it blinks try again until you get a solid blue light (it takes about 5-8 seconds) when that happens go to your phone and press search it will look for devices (it may find several)
look for your earpiece model and select it
it will ask for a code or passkey, type 0000. Then it's going to ask if you want to bond or pair click yes and it will connect
check on the connection manager again and your bluetooth should be on and connected.
if it works for you, don't forget to rate me
thx
6/5/2010 2:04:54 AM •
Motorola...
Answered
on Jun 05, 2010
Turning on my hs815
Battery is charged when the light turned from amber to green. After that, place bluetooth in ear and hold down on button until you hear a beep. You can also hold button until you see a light flash. If that doesn't work, try a different charger.
9/4/2009 3:28:32 AM •
Motorola...
Answered
on Sep 04, 2009
Pairing to LG Verizon
I have an LG as well (specifically the Voyager), and I found out how to connect them myself.
Go to the Bluetooth menu in the phone, and select "Add New Device". Hold down the talk button on the headset for about 5 seconds...the light will just be solid blue...then push okay on the phone. It should automatically connect.
4/11/2009 10:11:44 PM •
Motorola...
Answered
on Apr 11, 2009
Hs815
all passcodes are 0000
4/4/2009 7:43:14 PM •
Motorola...
Answered
on Apr 04, 2009
Motorola Headset Out of range...
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select HS815 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
1/22/2009 12:05:54 PM •
Motorola...
Answered
on Jan 22, 2009
Connection to Pantech
1. SWITCH ON THE POWERBUTTON BTHS AND PRESS THE PUSHBUTTON FOR A FEW SECONDS UNTIL THE
LIGHT STOPS BLINKING.
NOW YOU CAN SEARCH FOR THE BTHS. AFTER SEARCHING PAIR IT ,PASSSWORD IS 0000.
8/9/2008 1:06:44 PM •
Motorola...
Answered
on Aug 09, 2008
