20 Most Recent
Logitech Premium Headset Questions & Answers
Cut Cord
Please specify. What did the cat chew the wire to?
Logitech headset problems
the problem is with cable(wire)...the insulation got failed nd got short circuited....if warranty period is there u can get it replaced with a new one...
Mic not working properly
u need to check u r sound setting .plz click on sound icon in taskbar then click on sound property and recording there u can check u r mic if mic not working so srry dude u need to buy a new mic kkkkkkk
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
- Go to control Panel
- Sounds and audio devices
- The Audio tab
- Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Mic doesn work
same thing happened to me, it wouldn't even work when i went to control panel -> audio devices -> mic test i think i'm just going to return it for a different model.
headphones worked well though
Can't hear myself when recording
Hi There Try this,
VOLUME
Try Adjusting the vlume on your PC first. Check the volume on the Headphone too if there is one.
CLEANING
Using a dump clothe. Wipe the plugs with a twisting motion.
If all fails then You may have a Sound Card problem. Using a spare Speaker or Headphone check it if it works. If its not then its Defective and needs replacement. If its working then your Speakers or Headphones are defective. Try fixing them by cleaning or checking the Continuity of its cables using a analog Multi tester.
Hope This helps
ARGHH I CANT HEAR OR RECORD ANYTHING!?!?!?
Hi There Try this,
VOLUME
CLEANING
Hope This helps
I can't hear anything
Check volume icon on taskbar and ensure that MUTE is not ticked and then increase volume.
go to start/programs/accessories/entertainment/volume control- check all panels are working.
Then come back
I have just bought
Start on the Mac side by checking your sound input preferences. Do this by selecting under the apple pull down menu: System Preferences. Then get to the screen where you see all preferences icon's shown and select Sound. Once in the Sound preferences, select Input. Where is says "Select a device for sound input:" It is probably set to USB audio device since that worked for you. Look for Bluetooth Audio Device or similar name for your headset and select it. Speak into the h760 and adjust the input volume, you should see the input level go up when you speak. If not, your H760 bluetooth device is not properly paired. If your device does not show up, back up to the System Preferences page and select Bluetooth and follow instructions there. If that all is working but does not work in Parallels, inspect Parallels for Sound Input options and try to find your bluetooth device. Also check Windows sound input control panel to see that bluetooth is selected.
Hope this helps.
