20 Most Recent Sony AW-Q170A-B2 DVD RW Dual Layer Burner Questions & Answers
I had Sony dvd rw AW-G170A. It can read cds and
you might want to try and update the firmware on the DVD burner, find out with the vendor if there is a fw version and how to do it, if not I would suggest hiring a professional.
12/18/2017 4:23:04 PM • Sony AW-Q170A-B2... • Answered on Dec 18, 2017
Software
hi ruth , do you mean burning software for burning cd's or the driver to use the sony dvd rw aw-q170a so the computer to see it.... if it is burning software most times might find it from the company bought the computer from... at their website just have to check you can get from them as download... did you check see if you have any software reinstall cds for software... i know companies do not supply them anymore but could check. if the website does not supply the download to get software you might have to call the company of the computer see they can get the software reinstall disc for programs for like dvd rw you have...
6/23/2017 6:21:41 PM • Sony AW-Q170A-B2... • Answered on Jun 23, 2017
Optical media emulation
Uninstall while in safe mode. Go to your bios and make sure your CD Rom is detected. If it is then reinstall. If not then it isn't compatible with your computer
5/26/2017 11:54:40 PM • Sony AW-Q170A-B2... • Answered on May 26, 2017
Sony DVD RW AW G170A not detecting disk Was
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device if your computer came with a motherboard disk the drivers could be on it click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver
It could be a problem withthe lens, you should try cleaning the lens it's already gone bad there is no harm in trying
If you take a little risk can solve .
follow the instruction:
Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the acpower 3. remove powercable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.
now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected.. hope this helps you
10/12/2011 5:21:44 PM • Sony AW-Q170A-B2... • Answered on Oct 12, 2011
My sony dvd rw awg170a
Just click on the link http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
and also click on NOW RUN from right side box. It will automatically give youthe message, well or bad.
If the problem with the lens, you should try cleaningthe lens,with disk cleaner, it's already gone bad and there is no harm to take a risk to open ordisassemble the dvd/cd rw,click on the bellow link http://www.youtube.com/watch?v=WaiTJYHQCCg
  1. When running your pc, open the drawer.>
  2. clean the optical lance
  3. http://www.howtodothings.com/computers/a3631-how-to-clean-a-cd-rom-drive.html
  1. now you can fit to your pc
If it does the same problemplease change the cd/dvd rw because the lance has defected. If you need more information, reply me soon.
Thanks .
2/25/2011 7:16:18 AM • Sony AW-Q170A-B2... • Answered on Feb 25, 2011
Does not recgonize dvds or
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
12/7/2010 7:15:57 PM • Sony AW-Q170A-B2... • Answered on Dec 07, 2010
My Sony DVD RW recognise
make sure that the cd rom is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall or it might be a registry problem Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps
11/28/2010 7:44:01 AM • Sony AW-Q170A-B2... • Answered on Nov 28, 2010
How do you turn a dvd/rw into a blu-ray/rw?
You can't. You'll have to buy a blueray disk drive.
11/13/2010 5:10:58 PM • Sony AW-Q170A-B2... • Answered on Nov 13, 2010
Problem with Optical Drive SONY DVD RW AW-Q170A
Follow these steps
  1. Click on Start
  2. Click on Run
  3. Type in REGEDIT
  4. Click on OK
  5. Click on the plus sign (+) next to HKEY_LOCAL_MACHINE
  6. Click on the plus sign (+) next to SYSTEM
  7. Click on the plus sign (+) next to CurrentControlSet
  8. Click on the plus sign (+) next to Control
  9. Click on the plus sign (+) next to Class
  10. Click on the plus sign (+) next to {4D36E965-E325-11CE-BFG1-08002BE10318}
  11. On the right pane, click to highlight Upperfilters
  12. Right click on Upperfilters
  13. Click on Delete
  14. Click on OK
  15. On the right pane, click to highlight Lowerfilters
  16. Right click on Lowerfilters
  17. Click on Delete
  18. Click on OK
  19. Close the Registry Editor
  20. Reboot the computer
7/4/2010 2:56:59 PM • Sony AW-Q170A-B2... • Answered on Jul 04, 2010
The drive wont read any burnt dvds, and ones that
The actual dvd were also burned somewhere, did you burn your stuff correctly, try playing those cd on another computer.
CLEAN, WASH YOUR DVDs CAREFULLY DON'T DESTROY THEM.
It doesn't look like your dvd drive is faulty.
Please feel free to ask me for further information.
4/5/2010 2:45:27 AM • Sony AW-Q170A-B2... • Answered on Apr 05, 2010
Have toshibsamsung dvd+r/rw ts-h552b to replace cd
You will need drivers to write DVD's. You can try Ashampoo's Burning Studio Free (link below)
http://download.cnet.com/Ashampoo-Burning-Studio-Free/3000-2646_4-10776287.html
2/4/2010 6:33:04 PM • Sony AW-Q170A-B2... • Answered on Feb 04, 2010
Sony dvd rw- aw g170a cannot read dvd rw
It is a burner.
With DVD burners you cannot read disks, only write to them.
This cannot be fixed
1/5/2010 12:37:23 PM • Sony AW-Q170A-B2... • Answered on Jan 05, 2010
AW-Q170A-B@ Sony DVD RW Atapi CD/DVD ROM drive
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
12/30/2009 2:31:05 AM • Sony AW-Q170A-B2... • Answered on Dec 30, 2009
I have a Sony Dual Drive and the program has been
Access http://www.MajorGeeks.com and search for "AShampoo Burning Free Version 6". This is _FREE_ software for writing CD/DVDs. Yes, _free_.
12/14/2009 7:08:42 PM • Sony AW-Q170A-B2... • Answered on Dec 14, 2009
DVD RW Disappeared from system unexpectedly, help please
I hope this helps.
I have fought with the problem for the past few days including completely rebuilding windows --- with no success . The solution after 3 days was not software related, and not fault hardware either.
The problem occured after I had cleaned my cooling coils. There is no connection, but read on.
It was down to an earth screw. There is one screw missing from my case. When removing the back of a laptop be very careful to ensure that all the screws are replaced. In my case one screw was missing and I chose the worng hole "to leave empty" after cleaning my cooling coils.
Look carefuly any you might see set into the plastic fascia of the back of the computer a small circle with a dot/another small circle inside it. It is a very small symbol. This is the earth screw for the DVD/CD drive. Without it, for whatever reason, once windows boots up, then the CD will not be recognized unless there is a CD/DVD in the drive from boot.
10/12/2009 4:30:45 PM • Sony AW-Q170A-B2... • Answered on Oct 12, 2009
2answers
Driver for a Sony dvd rw AW-q170a
On Soney.com or Drivers.com, you should be able to download the driver. You might also check to see if it needs a firmware update.
9/25/2009 1:21:08 AM • Sony AW-Q170A-B2... • Answered on Sep 25, 2009
DVD R/W doesn't read the disc
Hello my friend, try to insert another brand new disk with no scratch to test if its still work. If it is not then try to ship back the device to its supplier or find technician in your place to assist you in order to check if that device is still working. Sometimes the laser eye of the DVD ROM is something to do with that. also try to  clean your DVD ROM if you have disk cleaner.  Hope thisadvice helps you. Just contact me if you need more assistance. Just reply to thispost. Thank you
6/17/2009 3:56:30 AM • Sony AW-Q170A-B2... • Answered on Jun 17, 2009
Sony AW-Q170A-B2 DVD RW Dual Layer Burner Logo
48 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Computers & Internet
Most Popular Question
sony dvd rw awg170a
  • Computers & Internet
