20 Most Recent
Sony VAIO VGC-LS21N PC Desktop Questions & Answers
I checked the ram modules and the thing is when i
One long beep + 3 short beeps denotes a video problem for Sony Vaio. Unfortunately it doesn't get more specific. If you have a video card, try re-seating the card. Try using a different monitor. Try upgrading the drivers (probably here: http://www.driverboost.com/lp/drivers/update/ati-video-drivers.php ) of course you will have to go to a different PC to download them onto a CD/dvd and try to run them. You might consider trying to boot into safe mode and doing a system restore. It could be many things. Without more information I can't really be of much more help. Hope one of these works for you.
Good luck
My sony vaio(VGC-LS21N)crashed,I took into a
Without a copy of the diagnostics they did, if it is the video card then they are correct. The video card is a part of the main unit (motherboard). You would need to replace your motherboard, which can be costly.
An alternative is that if you have data you want to keep is that you can put the hard drive in an external hard drive enclosure and get another laptop.
I have the same problem!
Your sony computer has a bad LCD backlight or LCD backlight inverter. Need a service repair by qualified tech.
How to open vaio flatscreen comp? (vgc-v620g)
Well its not that easy to dismantle it completely, however you can remove each module one by one and clean it, especially contact points wherever they may be with a piece of clean white paper(like newspaper). So cleam the ROM, Battery attachment. The fan assembly which is part of the power supply, The RAM sticks if you can locate it and then generally run the vaccum cleaner in the suction mode. Clean the keypad and ensure that no dust is trapped between the keys. Also make it a point to update all the drivers from the manufacturers website. Would'nt recommend complete dismantling but partial as stated above amd ensure that when you are using it to keep the fan area open so as to dissipate the heat quickly enough.........sodeep
The monitor stays blank but the computer turns on
- Monitor plug is loose
- Maybe you only think that your computer has started. Hit the NUM LOCK
key a few times, then CAPS LOCK key a few times. If you see the lights
go on and off, your computer really did boot up. IF NOT, then the
computer is really in trouble. In that case, unplug the computer and
RESEAT the RAM modules; then try to restart the system.
Good luck and Happy Computing!
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
