20 Most Recent Cisco Catalyst 2960 8-Port Ethernet Switch (WS-C2960-8TC-L) Questions & Answers
IP IOS Command not working with switch
you want to give IPs to your VLANs and also make physical interfaces members of a VLAN instead of giving IPs to physical interfaces
3/6/2009 2:33:03 PM • Cisco Catalyst... • Answered on Mar 06, 2009
FOC12085G1Z
Hi I have checked and no data found for that S/N Thanks
11/26/2014 12:29:51 PM • Cisco Catalyst... • Answered on Nov 26, 2014
How to switch on poe function at switch port
Hi Instructions telnet to the IP address of the Cisco switch Enter the telnet access password for the Cisco swict when requested, and then the "Enter" key. Type "enable" at the command prompt, and then the "Enter" key. Enter the Privileged Exec password when requested at the command prompt, and then the "Enter" key. Then enter "configuration terminal" at the command prompt, and then the "Enter" key. Type "interface fastethernet0/1," replacing the "fastethernet0/1" with the name of an interface in which you wish to enable PoE, and then the "Enter" key. Then, while in interface configuration mode, type "power inline auto" and then the "Enter" key. Repeat this step for each interface in which PoE is required. Type "end" at the command prompt and then the "Enter" key, copy running-config Below is some commands to run, I don't have any power on the interface but this will show you if this is working... SW1#sh power inline fastEthernet 0/1 Available:360(w) Used:0(w) Remaining:360(w) Interface Admin Oper Power Device Class Max (Watts) --------- ------ ---------- ------- ------------------- ----- ---- Fa0/1 auto off 0.0 n/a n/a 15.4 Run this command to see the interface is up..... SW1# sh interface fastEthernet 0/1 ' in protocol FastEthernet0/1 is up, line protocol is up (connected) SW1#sh cdp interface fastEthernet 0/1 FastEthernet0/1 is up, line protocol is up Encapsulation ARPA Sending CDP packets every 60 seconds Holdtime is 180 seconds Thanks
11/26/2014 12:23:48 PM • Cisco Catalyst... • Answered on Nov 26, 2014
WHAT DOES THE CODE PO188 MEAN FOR A 2007 SUZUKI XL7
Fuel Temperature Sensor "B" Circuit High Input - Faulty Fuel Temperature Sensor - Fuel Temperature Sensor harness is open or shorted - Fuel Temperature Sensor circuit poor electrical connection
8/29/2014 3:51:18 AM • Cisco Catalyst... • Answered on Aug 29, 2014
I forgot a password and i cant access a catalyst
You can only reset password this way: 1. Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch. Use the following terminal settings:
  • Bits per second (baud): 9600
  • Data bits: 8
  • Parity: None
  • Stop bits: 1
  • Flow Control: Xon/Xoff
2.Unplug the power cable. 3. Hold down the mode button located on the left side of the front panel, while you reconnect the power cable to the switch 4. Release the Mode button when the SYST LED blinks amber and then turns solid green. When you release the Mode button, the SYST LED blinks green. 5. switch: flash_init 6. switch: load_helper 7. switch: dir flash: 8. switch: rename flash:config.text flash:config.old Rename config.text to config.old. In that file the password is stored. 9. switch: boot 10. Enter "n" at the prompt to abort the initial configuration dialog 11. Type en to enable 12. Switch#rename flash:config.old flash:config.text 13. Switch#copy flash:config.text system:running-config 14. Overwrite the current passwords: conf term enable secret <new pass> enable password <new pass> line vty 0 15 password <new pass> login line con 0 password <new pass> 15. write memory 16. copy run start
6/20/2014 8:02:45 AM • Cisco Catalyst... • Answered on Jun 20, 2014
Cisco IP Phone 7945 booting problems Black screen and Speaker light stays solid green
talk to CISCO on there official forum. real start here https://community.cisco.com/ why go anywhere else. as rules can be fluid , for sure if security gets more tight every day. talk to them , actual
4/3/2022 1:03:22 AM • Cisco Computers... • Answered on Apr 03, 2022
What are the different types of Cisco Firewall which are used these days?
    these are the popular firewall for recent days: ·Packet filtering firewall ·Circuit-level gateway ·Stateful inspection firewall ·Application-level gateway (aka proxy firewall) ·Next-generation firewall
5/28/2020 3:50:46 PM • Cisco Computers... • Answered on May 28, 2020
What are the benefits of various versions introduced in networking Cisco ASA 5580 Firewall?
  • Packet filtering - ...
  • Stateful filtering - ...
  • Routing support - ...
  • Transparent firewall - ...
  • AAA support - ...
  • VPN support - ...
  • Supports IPv6 - ...
  • VPN load Balancing -
5/13/2020 4:17:06 PM • Cisco Computers... • Answered on May 13, 2020
Cisco Router Customer Care Phone {+1^84433O*233O^} numbeR USA
Su mensaje no califica como una pregunta o consulta para un problema, intente en otro lugar NO HAGA ESTE SITIO CON SU BASURA Lleve su BASURA a otro lado Su mensaje califica como SPAM
10/20/2019 6:49:42 AM • Cisco Computers... • Answered on Oct 20, 2019
Cisco Router Customer Service pHoNe #{+1*844~33O233O~} nUmBeR USA
Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
10/19/2019 6:53:00 PM • Cisco Computers... • Answered on Oct 19, 2019
Cisco Router TeCh SuPpoRT Phone nUmBeR @{1*84433O^233O~} USA
10/19/2019 6:52:32 PM • Cisco Computers... • Answered on Oct 19, 2019
Cisco Router Customer SuPpoRT pHoNe @{1*84433O^233O~} nUmBeR USA
ACURTNADA, Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
10/19/2019 6:52:19 PM • Cisco Computers... • Answered on Oct 19, 2019
2answers
Cisco Router Customer Care Phone'@#[+1^84433O*233O-] numbeR USA
Warning SCAM - DO NOT CALL THESE NUMBERS. These phony support numbers send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website
10/19/2019 3:17:29 AM • Cisco Computers... • Answered on Oct 19, 2019
CISCO tech support phone +[@;-{+1'8OO//8O3^1O69}] NuMbEr USA .Anita
10/17/2019 9:36:50 PM • Cisco Computers... • Answered on Oct 17, 2019
2answers
Cisco Router Customer Care pHoNe @{+l^84433O*233O} nUmBeR USA
THIS IS A SCAM- DO NOT CALL THESE NUMBERS. These phony support numbers send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website
10/17/2019 9:36:37 PM • Cisco Computers... • Answered on Oct 17, 2019
2answers
Cisco Router Customer SuPpoRT pHoNe @{1^84433O^233O} nUmBeR USA
THIS IS A SCAM -- DO NOT CALL THESE NUMBERS. These phony support numbers send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website
10/17/2019 9:36:16 PM • Cisco Computers... • Answered on Oct 17, 2019
2answers
Cisco Router TeCh SuPpoRT pHoNe #@{+184433O^233O~} nUmBeR USA
-THIS IS A SCAM -DO NOT CALL THESE NUMBERS. These phony support numbers send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website
10/17/2019 9:36:01 PM • Cisco Computers... • Answered on Oct 17, 2019
2answers
Cisco Router Customer Service pHoNe #{+1^844~33O233O+} nUmBeR USA
WARNING! *SCAM*, DO NOT CALL THESE NUMBERS. These phony support numbers send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website
10/17/2019 9:35:31 PM • Cisco Computers... • Answered on Oct 17, 2019
2answers
Cisco Router TeCh SuPpoRT nUmBeR @{1^84433O^233O} USA
WARNING! *SCAM* -- DO NOT CALL THESE NUMBERS. These phony support numbers send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website
10/17/2019 9:34:35 PM • Cisco Computers... • Answered on Oct 17, 2019
Cisco Catalyst 2960 8-Port Ethernet Switch (WS-C2960-8TC-L) Logo
Popular Tags
2 questions posted
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Catalyst Cisco
  • Catalyst Cisco
Most Popular Question
ip ios command not working switch
  • Computers & Internet
