if you know how to solder its most likely the toshiba chip under the heat sink, here is more in depth, i wrote this up about 3 to 4 years ago
Ciscoel Nino - "since numark fixed thier overheating problems by adding avent under the platter, i think that what is happeing is that our DCMOTOR DRIVER IC (Toshiba TA7259P) has gone bad what i am going to do itorder this, install it and let you know the deal. there only 5.80 apiece and shipping is like 8 dollars. ill get back to you. I amguessing it is sort of like computers CPU, like its got thermal gel/grease on it and all that fun stuff. It is on the Motor's board heres the image
(IMG:
http://img97.imageshack.us/img97/9139/ttx19tl.jpg)
after i install it too, i am also going to cut vents like this under my platter like the updated versions
(IMG:
http://img97.imageshack.us/img97/8523/ttxvents8pn.jpg)
also take your time when installing the chip.
1. its sensitive to static.
2.buy a low heat soldering iron.
3.do each solder point at a time, wait a few seconds for the IC to cool off. then approach the next.
also open your ttx and see what exact IC you need. Mine was a Toshiba TA7259P. Also when you order that, order small tube of thermal paste.
http://www.audiolabga.com/ for parts ordering"
