20 Most Recent Technics SL-BD20D Turntable Questions & Answers
I recently purchased an onkyo tx-nr626 receiver with phono input. When connected I don't get full sound.
Different cartridges put out various levels based upon their technology - make sure you are using the proper input for their output. A line level input 1V P-P won't work on most phono cartridges and will require a preamp to boost it to the higher level.
12/26/2014 4:02:32 PM • Technics... • Answered on Dec 26, 2014
I recently purchased an onkyo tx-nr626 receiver with phono input. When playing albums , I don't get full sound. Sound is clear but not full and loud.
12/26/2014 4:01:58 PM • Technics... • Answered on Dec 26, 2014
Why douen't my technics turntable spin?
Take off the rubber mat and see if the belt is off the aluminum platter the record sits on you should be able to see the rubber belt when the mat is removed. If it is not there or broke it will need replaced.
5/30/2014 10:41:44 PM • Technics... • Answered on May 30, 2014
Turntable playing too slow
there is a (v.r) for speed in side look for it and turn it a little
3/24/2014 8:41:27 PM • Technics... • Answered on Mar 24, 2014
Need aground cable
The ground cable is usually a part of the audio cable. A red lead(right channel) and white lead(left channel) and a black lead. If there is no black lead, you can connect any wire to the metal portion of the turntable and the ground lead on your receiver. For more information, or should you have further question, please visit my website at audioserviceclinic.com. You may contact me through the website. Thank you.
12/18/2013 12:18:32 AM • Technics... • Answered on Dec 18, 2013
2answers
Turntable will not turn
There is really nothing else to it. If the drive belt is in tact, and properly installed, and the spindle motor is rotating properly, your turntable should rotate. There's nothing else that rotates the platter. Just make sure the belt is wrapped around the spindle motor.
- Davis
DIGITAL ANALOG THERAPY
www.repairnyc.com
12/18/2013 12:14:01 AM • Technics... • Answered on Dec 18, 2013
What is the tonearm setting
Hi, 1.25 grams. Cheers john. Styluscity
11/28/2013 8:18:05 AM • Technics... • Answered on Nov 28, 2013
I have a problem with the turntable I just purchased...
Hi, remove the platter and check that the belt has not come off. Cheers john. Styluscity
11/24/2013 11:02:37 PM • Technics... • Answered on Nov 24, 2013
Wont change speed
Hi, platter needs to be rotating when you change speeds. Cheers john. Styluscity
11/24/2013 10:46:55 PM • Technics... • Answered on Nov 24, 2013
Needle skating badly; Can I adjust the stylus
Too causes of this problem. One the stylus is worn out. Two not enough pressure to the stylus. At the end of the arm is a weight this should move up or down. If you can see numbers on it increase it slowly to the higher numbers, trying it as you go. The trick is to apply the correct weight to keep the stylus in the grooves and not here a rumbling sound from too much pressure.
7/4/2011 3:07:06 PM • Technics... • Answered on Jul 04, 2011
I dont have the orginal
You don't need the original ground wire for Technics SL-BD20D turntable,
any plain cable can be used for this purpose...
you should connect turntable to your pre amp,should be a "phone" input at the back...
here are some suggestions for grounding....
  • Plug in a surge protector to the outlet, and then plug all the components into that surge protector
  • Connect a ground plug to the surge protector and then plug the ground plug into the main outlet. A ground plug is available at any hardware store, and turns a three prong connection into a two prong. Ground plugs help eliminate 60 cycle hum.
  • Connect the ground wire from your turntable to the ground wire connection on the receiver. If this doesn't work, looking on the back there should be a grounding point,
    Unplug your receiver.. Split a wire and attach one of the splits to the receiver where you will see the text, "ground" or something similar. Attach the other end to something metal such as a pipe that goes into the ground. Secure with electrical tape. Plug in.
    connect the ground wire to a screw on the electrical outlet.
    Take care and please Remember to rate/vote and give me 4 Thumbs Up
    for Helping out the Community :)
    Hope this helps!
    6/22/2011 7:37:19 PM • Technics... • Answered on Jun 22, 2011
    I have a technics slbd20d
    u mean the recor speeds and slows down? if its an older turntable there is some play in the bpms thats why most people get direct drive. my sugguestion is to look it over and tinker w things but dont break it. im sure you can find a manual online
    5/6/2011 12:52:44 AM • Technics... • Answered on May 06, 2011
    How to put back the belt on a turnt able
    hi,
    Just watch the following video to replace the belt in your turn table.
    ok
    4/4/2011 5:32:03 PM • Technics... • Answered on Apr 04, 2011
    I have a technics sl-bd20d
    Poor ground at the phono cartridge. Turn your receiver off and remove/reseat the cartridge and/or the tiny leads to it.
    4/3/2011 11:14:02 PM • Technics... • Answered on Apr 03, 2011
    Technics SL-BD20D Turntable Logo
    45 questions posted
    Top Technics Audio Players & Recorders Experts
     Grubhead
    Grubhead
    ZJ Limited
    ZJ Limited
    Kolbrun...
    Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
    View Most Popular
    • Technics Audio Players & Recorders
    Most Popular Question
    dont orginal
    • Audio Players & Recorders
