20 Most Recent
Technics SL-1210M5G Turntable Questions & Answers
I am getting extremely faint sound from the left
If you switch the cables so the left channel plays into the right of the amp and the sound stays dead in the left channel of the amp it's not the cartridge that is at fault by your amp. Amps have a magnetic cartridge pre-amp built into them for turntables. This can go faulty, but won't effect any other device (CD etc). Most of these pre-amps are a single IC. Which will need to be replaced.
11/26/2014 10:50:28 PM •
Technics...
Answered
on Nov 26, 2014
Left channel suddenly gone quiet, left channel
Hi, firstly switch the output rcas over on your amp/mixer and see if the problem stays in the left channel or has now gone to the right. If it stays in the left it is a problem with your amp/mixer. If it moves to the right the problem is in the turntable. Likely causes for turntable problems are cartridge being damaged or stylus damage. If you have another cartridge try that. Cheers john
11/22/2013 3:28:33 AM •
Technics...
Answered
on Nov 22, 2013
Left channel not producing any sound, right side
Disconnect the wires to the cartridge. With the amp on. Touch each wire (one at a time) with your finger. Two of the wires should buzz (1 left, 1 right) if the left doesn't buzz either the connections are faulty or the pre-amp in your amp is.If you get a buzz on the left, replace the cartridge.
11/16/2013 9:47:35 PM •
Technics...
Answered
on Nov 16, 2013
Platter jurk
Not a pitch issue. This is a drive issue. The drive circuits are located underneath the turntable platter, on the main PCB. They usually go bad, more recently then before, unfortunately.
Not an easy fix, but not an expensive fix either, as the components are relatively cheap. It is time consuming, and if you have someone work on it who doesn't know what they are doing, could run up a nice tab on the repair. So be careful where you take it to. Ask them if they've worked on Drive Issues on 1200s before. If they look at you like, huh? STAY AWAY.
- Davis
DIGITAL ANALOG THERAPY
www.repairnyc.com
www.1200s.com
8/22/2011 9:12:24 AM •
Technics...
Answered
on Aug 22, 2011
Gain output is not equal on left and right I
Is there a balance (LR) for the input on your preamp?
Is there an anti-skating adjustment on the tt? That controls the lateral pressure on the needle. Read the manual.
try a different set of cables
9/1/2010 9:51:40 PM •
Technics...
Answered
on Sep 01, 2010
M5g does not keep speed
Your belt is probably worn and needs replacing. Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
8/18/2010 4:30:47 PM •
Technics...
Answered
on Aug 18, 2010
Hey...
Most sound problems are caused by cartridges. However in some cases the deck is not to blame, but the amp it is connected to is. If you have another amp make certain the problem is with the deck, by trying it on that first. Remember that other devices can work fine on your amp, but the turntable might not. This is because your amp has another pre-amp just for turntables. It could be this pre-amp that is causing the problem!
1/20/2010 5:08:51 PM •
Technics...
Answered
on Jan 20, 2010
Techics sl-1210s m3 turntable spins back on itself
You have a fault on the quartz-lock speed control electronics. It may be a simple fix, it may be not.
It will require specialist investigation. A Technics dealer should be able to advise you, and arrange shipping back to Technics for repair if you decide that is the best thing to do.
1/25/2009 2:31:30 PM •
Technics...
Answered
on Jan 25, 2009
