20 Most Recent
Razer DeathAdder RZ01-00150100-R2M1 Questions & Answers
My Deathadder stop working....it just
If you are on PC go to the "Device Manager" in the Control Panel.
Under USB or Mice see if its connected and/or has a problem. Usually driver issue. You can click uninstall then, unplug the mouse then plug it back in.
Razer deathadder Mouse wont move on screen just
i have a similar problem with my naga, i have to go in through the control panel and disable and reenable with my keyboard (which i have hotkeyed now) almost every time i turn on my computer. I use it for warcraft, also have ACS, norton, and spybot installed
My Deathadder right button is
I have the exact same issue! It makes the click sound and everything but it won't freaking work about 10%-25% of the time.
Deathadder left click problem
I've had DeathAdder for about 1 year and it started to do EXACTLY what previous people described, double-click instead of single, stops firing when I hold it in QuakeLive/Counter Strike (have to press it again, etc. etc.) windows cannot be dragged because it needs to be holding left drag, never had this before. same happens on MULTIPLE machines with this mouse, tried 2 diff laptops and desktop and even mac computer....so it's must be something with the mouse not OS/Computer
My DA 3500dpi just stop working, now my cursor
Did you see the configuration in Control Panel? You can try to adjust it according to the manual.
http://www.razersupport.com/master-guides/RzrDA3500_Eng.pdf
Would you like to check the bottom of the mouse and make sure there is not dirt or hair sticking to it. The mouse is very sensitive and will pick up imperfection. You can try to unplug it from the USB port and replug it and make the system detect it.
There should be no battery within this mouse because USB port will bring the power for it but unless you can see a sign about battery on it.
My razer Deathadder has been
Hi there thanks for asking you should try to press the bottom part back into position be careful not to damage it. make sure you look carefully while pressing it after you done this you can try using mouse again this should solve the problem.
Razer(ghost mouse)
hi,
have you made sure that the laser sensor on the bottom of the mouse it clean?
and the surface you are using it on is not too shiny as this can throw out the laser?
Hello, i wanted to know how to clean a Razer
What you should do is take hot water and a old anti static cloth"The ones you clean your screen with"and just make the cloth damp and wipe the pad in one direction just incase of scratching it...if you want to dry it use the same but dry cloth and you should be sorted out...with no scratches or anything to your game pad .
This mouse comes with a very small bundle of some quick start guides and small getting started guide.
It also comes with a drivers disc try using it.
More info here
http://www.techpowerup.com/reviews/Razer/DeathAdder
Razer Deathadder crashes computer
I think that cable of your razer is broken and some cables are shortcircuited, don't plug it in computer, you could ruin your motherboard. If you want your mouse working and have some technical skills, buy some usb cable with same plug as mouse have and replace it
It doesnt work...
Normal
0
Try disconnecting the Mouse Receiver from the
USB port and reinstall the CD software program. When
the program asks you to connect the Mouse Receiver to the USB
port, do so and it should work.
Hope this helps. Bud
