20 Most Recent
Samsung HL-S5086W 50" HDTV Questions & Answers
Tv says check fan 2
A fan has failed--possibly is just dirty. I think there are 3 of them--2 near the lamp and one behind the DMD module. If not--check the fan connectors and make sure they are tight. if all ok--a fan needs replaced.
11/26/2014 4:08:58 AM •
Samsung...
Answered
on Nov 26, 2014
I am not getting video on my tv
there are several different inputs on back of this tv. the correct video input must be selected from the menu setup screen. some of the older cable boxes also require a cable card . check with your cable company.
6/29/2014 1:20:26 PM •
Samsung...
Answered
on Jun 29, 2014
HL-S5086W turns itself off
if your tv is dlp. the blub is probably the cause. i have a r5087 and had same problem. replaced blub and set works fine
11/30/2013 6:34:33 PM •
Samsung...
Answered
on Nov 30, 2013
TV goes off after 20 seconds Samsung HLS5086wx
First Take off the Lamp Door and replace it back the way it was secured with all of the screws. Doing this will reset the safety interlock switch which heats up and opens the circuit causing the set to shut down. After doing this and the set still shuts down check the lamp. Depending on the amount of hours on the lamp it may be a bad lamp. They will fail with out any obvious signs. If the set shut down and goes straight to the Stand By condition then you have a bad Power Supply. If you hear a whining or buzzing sound then you have a bad Color Wheel.
1/26/2013 10:23:22 PM •
Samsung...
Answered
on Jan 26, 2013
My tv keeps turning off right after i turn it on
I have a samsung dlp tv and had a similar problem. Fortunately, I also hava a samsung color laser printer that had a fan problem for which there was an easy fix. It turns out that the fix for the tv is the same as for the printer - oil the fans. It is really easy and takes about 15 minutes. You have to unplug the tv and remove the rear plastic plate( about 9 screws) The main fan is on the middle tray with the projection equipment. you have to remove two screws and disconnect four electronic connections to remove the tray. Then unscrew the fan holder and turn the fan over. Remove the sticker and place a little light maching oil on the axle. Give it a couple of spins and replace. Put everything back before plugging in and start the tv. It has worked great for me since.
7/25/2012 2:51:28 PM •
Samsung...
Answered
on Jul 25, 2012
Dlp chip for samsung
buy a light engine as the chip alone is over 200 or replace the set.
5/14/2012 2:16:40 PM •
Samsung...
Answered
on May 14, 2012
Dim screen.
hit the menu button and go to setting and look for brightness. might fix the problem
2/27/2012 1:01:12 PM •
Samsung...
Answered
on Feb 27, 2012
My samsung keep turning off.
The turning off problem is just a symptom.
The turning off is the protection circuit shutting down the TV because a problem inside the tv is detected.
The TV must be tested to find the problem.
8/11/2011 9:30:20 PM •
Samsung...
Answered
on Aug 11, 2011
